Question about Panasonic PT-60LCX64 Television
Air filter keep popping on screen and shut off after 1 minute.
Air filter cleaning message keep coming on is there a way to resset this problem. This tv has been nothing but trouble since I had it.
I had the same problem with my Panasonic tv, just 3 days after a technician came out to fix "fuzzy spots" which were multi colored, but mostly green spots. I really thought that the technician was in some way responsible, but Panasonic insisted that there was no possible way he was. It was going to cost $240.00 for him to come out to clean the air filter, and both the technician and Panasonic insisted that I couldn't do it myself. I had decided to buy a new tv to cut my losses. My boyfriend talked me into trying to fix it, we are both sort of mechanically inclined, and it was going in the trash anyway.
We took the back and top off the tv. It took some looking, but we finally found the filter, just over the projector. We removed the cover, it has to be done from the back of the tv, it is black and held on by 4 small screws, be careful not to drop them into the tv, we dropped one, but it shook out. We vacuumed the filter really well, and vacuumed around everywhere. We put the tv back together, not expecting it to work, but thinking at least we tried. It works great. It has only been a few days, but it seems like the problem has been solved.
Good luck if you decide to try. I have decided not to put another penny into the tv.
Posted on Feb 15, 2009
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Jan 06, 2014 | Panasonic PT-40LC12 40" Rear Projection...
KONICA C 352 ERROR CODE C-D 231
TRy reset:
Turn OFF the copier.Press and keep pressed thje Utility key and turn ON the copier.
Keep pressed the Utility key and wait will the Trouble reset message displayed.
Release the Utility key and and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 09, 2013 | Office Equipment & Supplies
A message keeps popping up saying I need to clean the air filter then the tv shuts off on it's own. It's a panasonic 60 inch projection
there is a louvered air intake panel on either lower side of tv. there is 1 or 2 screws the filter is right behind that panel.. take it out and clean it with warm dishsoapy water and pat dry on a flat surface with paper towels then reinstall. your th will not come on till the panel is screwed back into place. there is a microswitch type sensor that makes sure that the screws are in place...goodday
Nov 13, 2009 | Panasonic PT-60LCX64 Television
Air filter cleaning needed message comes on and need to clean and shuts down after 1 minute. what do i do? where is the filter i took the back off and no filter. i blew it all out. anything else?
There is a side panel where the Lamp is located and held on by a screw or two.
Open that compartment and vacuum out all dust. Also any fans should also be cleaned.
Jul 29, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Trouble shooting problem, Please help!
probably a programming issue ( in a board or something ) might need to call a tech to come out or take it to a shop. under warranty?
Aug 14, 2008 | Heating & Cooling
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Jun 11, 2008 | Panasonic PT-52LCX66 Projection Television
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Panasonic PT-60LCX64 Television Logo
621 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
