Question about Philips 64P8341 64" Rear Projection Television
No set up menu menu does not come up using remote or tv front panel buttons.
  • 4 more comments
  • Robb1971 Jan 08, 2009
    Tried to reset by unplugging several times with no luck
    What internal part would cause this malfunction.
  • Robb1971 Jan 09, 2009
    volume as well as channel buttons on the front of the tv work fine as well as using the remote its the options such as the sleep timer, menu and display functions that are not working for some reason. is there a module or card that controls these functions?
    on this model the vol up/down buttons pressed togeather are used to access to menu options.
    I believe its 5 to 7 years old.
    I purchased a universal remote and a replacement OEM remote still does not bring up the options menus
  • 2,071 Answers
Take your remote control and check it if its working or not .Take a cellphone with camera this is the latest gadget to check all kinds of remote control If its ok. In your cellphone open the camera then focus it infront of the remote control were the IR led or eye is located. Then press any button of remote control, you will see it glowing from the remote infrared eye while pressing any button If its okey, If the remote is defected it will not glow. Check all the button by pressing one by one if its glow If not then the problem is your remote .There is three causes why its not functioning first teh IR led or the eye is loosed contact or cold solder ,secondly the crystal 500,501,503,504 whatever number you have ,it is a square in shaped has only two colors either yellow or blue thirdly is the system memory IC is no available in the market . In the Infrared eye of the remote you must renew or resoldered the parts joints,so it will contact again and resolder all soldered parts there . Then if your remote control is glowing whatever button you press then it is good 100%. Remote is fine and TV is not responding then the problem is the TV sensor receiver..The TV sensor receiver is in infront panel of the TV maybe loose contact connection or cold solder becaused you said you can operate the TV manualy its okey in remote not working.If you have a knowledge of electronics you can open the TV and do soldering works if not its better you bring this to electronic TV shop to avoid electricuted maybe this cost only you $50.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 11, 2009
    Sergeant:
  • 431 Answers
The IR part of the remote would have malfunctioned or the buttons would have misplaced. Remove the remote casing and check for sufficient power supplies in all parts of the IR component. check the buttons whether they press the correct portion of the printed circuit board.
Posted on Jan 09, 2009
    Genius:
  • 1,011 Answers
Sir,
Do u using universal remote? if you use you must program your universal remote with the correct codes required to activate your TV. If not there is problem with menu sensor at the tv. open the front panel check whether the wires are short circuit or any fault in solder joint. U must replace the menu sensor in tv. Contact technician
thanks
g.luck
  • 108 Answers
The issue is with the ssb (small signal pcb). It is a little pcb that plugs into the main pcb. part number is 313912725871
  • 565 Answers
If remote is not working then buy your self a universal remote then u have the possibilty to enter menu
  • 89 Answers
How old is the tv?
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
does the tv have a menu button on the tv and the remote? if so it sounds like the motherboard isnt recognizing the command that is given to it by either the remote or the button on the front of the tv.
thanks
tom
Posted on Jan 08, 2009
  • Thomas Jan 08, 2009
    i dont know what part or parts would cause the problem but that is why i would suggest having a tv tech. look at it and they can tell you exactly what is wrong
  • 594 Answers
Please advise. does your volume,on/off,channel buttons still work on the t.v. set and the remote it's self?
  • 837 Answers
Unplug the tv for 5 minutes and see what happens
Posted on Jan 07, 2009
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Try to press the menu button hardly in your tv after reset . If your problem still continues then its due to failure in internal connection . The sensor is not working properly for receiving signal from the remote.
    Sergeant:
    Champion:
  • 239 Answers
Unplug tv for 5 minutes then try again
How do i get service mode on Toshiba TV22DV615DB
1. Turn the TV on.
2. Press the {MUTE} button three times on the remote.
3. Press the {MUTE} button again on the remote and hold.
4. Then press the {MENU} button on the TV's front panel.
5. Release both buttons
6. There should be a letter "S" on the upper right of the screen.
7. Press the {MENU} button on the TV's front panel again.
8. You are now in Service Menu.
9. Use the {CH+} or {CH-} buttons to select the item.
10. Use the {VOL+} and {VOL -} buttons to adjust the value.
11. Turn the set off to exit the Service Menu.
Oct 24, 2012 | Toshiba 22DV615DB 22 INCH LCD TV COMBI IN...
Front panel lock
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 18, 2012 | RCA 20F424T 20" TV
How to unlock your front panel of tv
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jul 24, 2012 | RCA TruFlat 27F520T 27" TV
Do i unlock the front panel lock on a RCA 27V55OT
Jul 09, 2012 | RCA 20F511T TV
Have a model # G35830WK that is in parental control how do we get it off
Hello
You should have its original remote control to unlock this set. If you ahven't one, just try to get it from any of your friends or relateives, who owns the same type of set. After unlock, you can use any other universal remote control. To unlock it:
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
**If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
Jul 08, 2011 | RCA Televison & Video
How do you reboot and unlock tv
Hello
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 28, 2011 | RCA L32HD31 32 in. LCD HDTV
Can you turn off the FPA lock without an original remote? If so, how?
If you remember your pass word then you can use any remote that operates the TV to reset the menu selection. However if you don't remember the password, then sorry, the original remote must be used.
Below is the procedure to set up the menu for front panel lock, unlock and the password reset.
Front Panel
Selecting this option lets you lock (disable) or unlock (enable) the TV's front
panel buttons. The remote still tunes to any channel so remember to remove
access to any remote that can operate the television.
1. Choose Parental Control from the Main Menue and press the OK button.
2. Enter your passworcd.
3. Press the down arrow to highlight Front Panel.
4. Press the right or left arrow button to choose unlock (_) or lock (_).
I don't remember my password and I want to unlock the TV
If you forget your password, you must reset it. Make sure the TV is of. Press VOL- (down) on the TV's front panel and then
CLEAR on the remote for approxhnately 5 seconds. The TV turns on. Enter a new password next time you access
the PARENATAL CONTROL menu or the TIME_menu.
Feb 17, 2011 | RCA 20F512T 20" TV
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Ok
Jan 06, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Parental Lock Code
If you forget your password you can reset it. Make sure the
TV is off. Simultaneously press and hold VOL< on the TV’s front
panel and CLEAR on the remote for approximately 5 seconds. Enter
a new password next time you access the PARENTAL CONTROL
menu.
Jan 28, 2008 | RCA 27V530T 27" TV
Philips 64P8341 64" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
