Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Small yellow piece came out of the psp that loads the umd discs.
How do u put the small yellow piece back in the psp.
  • scha46018 Jan 07, 2009
    how to put the small yellow piece back in the psp
  • 21 Answers
We offer PSP repair services. We can fix this issue for only $34.99.
Email me if your interested - sbl.games@gmail.com
Posted on Jan 10, 2009
  • SBL Games Jan 10, 2009
    If you are going to fix it yourself you are going to have to open your PSP. If the yellow piece has fallen out you will have to replace the whole switch that it belongs to. Opening your PSP will void your Warranty. If you are under Warranty still have Sony fix it. Otherwise, if you aren't under Warranty we can fix it for you. Watch our video on how to replace your LCD screen for instructions on how to open it. We can also fix it for you. The offer still stands.
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
PSP 3000 won't load games
u might wana check if theres any pieces mising in the back where u insert the gaame
Jan 13, 2009 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp not reading umds
Your psp umd laser might be broke if you go to ebay.com and type in psp repair you will see people will fix them.
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
PSP won't play any games
the reason the umd wont load is because someone shut the psp off when the game was loading. so whoever did that just messed up your psp. i know cause someone did it to mine now i have to get it fixed or buy a new one. and to get the psp fixed its not guna be cheap.
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Where is the UMD?
UMD is Universal Media Disc, its a small disc are used for PSP.  press the "eject" button on the top to open the disc tray. Usually the problem its not from the UMD, but from the console.
The first check the version you are running on psp, >> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP. If the UMD has a high version than ur console, u need to update ur psp.
plz visit my blog, for psp update guide.
Oct 28, 2007 | Sony PlayStation Portable (PSP) Console
Psp
is it a scratching scrapping noise?
as some UMD cases, as in the plastic thing around the disc colapse or come apart this stops the disc spinning properly.
Check the plastic on the UMD... click any sides together that may be loose / or make sure the case isnt pushing on the disc.
Also open the PSP, hold it upside, gently shake it & blow into it.
Put the UMD back in & try again.
Oct 03, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
