Question about Thermador SC272T Electric Double Oven
Cleaning wondering why I can't leave in the oven racks during the cleaning process.  It sure would be a nice treat to have them cleaned also. Thanks
  • 126 Answers
If you leave the racks in it will dull them and over time possibly even weaken them. There are ovens available now that have a special coating and can be left in the oven during the cleaning process. I personally have very dull racks in my twelve year old oven and they still hold a turkey just fine!
Posted on Jan 07, 2009
    Problem Solver:
  • 5 Answers
Usually racks are not left in because the high heat generated causes the chrome finish to become dull and darker. If you don't care what the racks look like I would say go for it.
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Do we leave the racks in the oven while cleaning it ?
    Hi.
    I assume you are referring to the "self-clean" function of your oven, in which case, the answer is no. All racks and the broiling pan, etc should be removed from the oven before initiating self-clean mode.
    I can't give any specific instructions for the self-clean mode on your oven as you have not specified a brand or model number. If you need any further assistance, please post back with these details.
    Please note: The high temperatures generated during "self-clean" have been known to cause the door locking mechanisms on many ovens to become stuck in the closed position. This often requires a service call to rectify the problem. If you are planning to use the self-clean before cooking your Christmas meal tomorrow, please bear this in mind. There is little chance of getting a service call between now and then.
    Hope this helps.
    Happy holidays!
    BElectric.
    Dec 24, 2010 | Ovens
    Do I leave the oven racks in when using the self cleaning feature?
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Nov 06, 2010 | Whirlpool RBS275PD Electric Single Oven
    After self cleaning the racks no longer fit properly. We removed them during the cleaning cycle but it appears that the oven walls have warped and the racks are to small. Is there some way to adjust the...
    Seems like you found out the hard way what I wrote about in this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Aug 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    GE Monogram Trivection - self-clean cycle with oven racks in
    Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
    Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
    Cleaning racks
    I assume you have tried leaving the racks in while on self cleaning mode! so as a chef also i'll tell you they have a cleaner called oven and grill cleaner, but ht eobject needs to be hot! about 200 degrees, but it will melt off anything! I mean anything!. BE carefull not to smell fumes, please
    Mar 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
    How to clean oven
    We called a neighbor who has a similar oven. Thanks for you interest. Utne
    Dec 13, 2008 | Dacor ECD230 Epicure Electric Double Oven
    Electrolux Icon Oven won't self clean - "Remove Racks" displayed
    I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
    Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
    Cleaning before the self-clean - how much?
    If you get most of the big chunks out that should be good, make sure there is no tomato sauce etc on the porcelian as it can leave a stain. Don't forget to take the racks out as they will not slide well if left in durin self clean.
    Sep 01, 2008 | KitchenAid Architect Series KEBC107KSS...
    Thermador SC272T Electric Double Oven Logo
    378 people viewed this question
    Top Thermador Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Are you a Thermador Oven Expert? Answer questions, earn points and help others
