Question about JVC GR-DVP1 Mini DV Digital Camcorder
Stop button problem
Dear Sir, Since few months, my gr-dvp1 undergoes a certain issue. When playing a cassette (play mode),there is not any particular problem but when I try to stop the play mode by the stop touch(d-sound) the cassette never stops but the volume scale dislpays on the screen. Could you please help me to resolve this problem. Thanks Rawgen
  • 38 Answers
This was a common failure with this model and requires replacement of the control block assemble. This is an assembly with several functions tied together in one preformed unit with a flexible cable arrangement. This ordinarily is a pro repair situation. They have an upgraded part for this. Could be a bit pricey however. Good luck, magic seadog
Posted on Aug 12, 2007
Stop Paying .. ????
if the take up side gets stuck it could feed excess tape and stop the mechanism. Look to see if both reels are turning when you push play. Remove cassette door for a better view if possible.
Make sure your tapes have NO slack in them. Fast forward and rewind one cassette all the way, then try again looking to see if both sides are turning. If not, you may have a belt that is old, stretched and slipping or it's split apart or just fallen off
Sep 11, 2015 | Yamaha Audio Players & Recorders
How do I clean the head when it gives you an alert?
two ways, buy a mini dv cleaning cassette, two if you do not have one, put the cam in play mode, hit play, than fast forward button for a min, the tape going fast sometimes cleans the head. not just fast forward but play, than ff so the tape is hitting the head, other than that, the cam has to be taken apart and the heads cleaned with the proper cleaning solution and PROPER brush as not to hurt the fragile heads
Dave
Sep 15, 2014 | JVC GR-D250 Mini DV Digital Camcorder
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
What is safe mode?
Try cleaning the cassette heads by inserting a JVC Cassette Head Cleaner and press play.
Aug 08, 2010 | JVC GR-D270US Mini DV Digital Camcorder
How can I video with the memory chip in my camera GR-DX307
Insert memory card, set to camera mode and set to memory, then hit the E-MAIL/INFO button and then you can press rec start/stop button as if your are recording on tape. It is a low quality video(email clip). To play, slide the power button to PLAY and press select(beside E-MAIL Button) and choose E-MAIL CLIP. Thats it. Good Luck
Mar 09, 2010 | JVC GR-D370 Mini DV Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
JVC GR-DVP1 Mini DV Digital Camcorder Logo
60 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
