Question about Mitsubishi VS-5043 50" Rear Projection Television
Picture distorted on Mitsubishi WS-65909
We turned off the TV and turned it back on 10 minutes later and the picture was distorted with a horizontal curved line at the top and a horizontal curved line at the bottom. On the subtitles and credits, there are red words and green words. The letters aren't aligned together.
  • steve2356 Jan 07, 2009
    How do I know which IC is the convergence one? Is it soldered in?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, is your concern something like the image below? Picture distorted on Mitsubishi WS-65909 - e91c8b8.jpg
If yes, then as the others posted, it is a convergence issue. Others have successfully performed a DIY (do-it-yourself). You might be able to pick up some hints, tip and procedures form here. Parts are readily available from online, an ecample is here.
This of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY, perhaps your best bet would then be to seek the services of a qualified professional. If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options and consider a replacement.
Good luck and Thank you for using FixYa.
Posted on Jan 07, 2009
    President:
  • 1,952 Answers
This is a convergence problem. Either there are bad connections on the convergence ICs or the ICs are defective. These are large black ICs attached to a heatsink and should be marked STKxxx. Try resoldering the pins first. If that does not resolve the problem, replace the ICs.
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Jan 07, 2009
    Look for the convergence ICs. They will be large black ICs attached to
    a heatsink and are probably marked STKxxx. Try resoldering first. If
    that does not fix it, replace the ICs
    The convergence IC is bad. It should be an STKxxx. a rather large
    black IC screwed to a heat sink. If you have any experience with
    soldering, you should be able to replace this part and save yourself
    the labor charge. THe part should be available on-line for about
    $25-$30 or so.
    The vertical Ic should be attached to a heat sink and be a 9-pin inline
    chip. The part number on the chip . You should be able to get this part on-line.
    Replace it and that should take care of the problem. If the picture
    seems not right after replacing the chip, then additional parts will be
    needed. These are also available and inexpensive (capacitors).
  • 4,472 Answers
It sounds like the convergence is out of alignment. Most likely you will want a professional to have it realigned or diagnose a problem with the convergence circuitry.
http://direct.where2getit.com/cwc/apps/w2gi.php?template=search_new&client=mitsuservicer#?mid=174138
Follow this link to locate the nearest authorized service center where you can get an estimate and usually in home service as well with the bigger tv's. If you need any further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    Genius:
  • 1,550 Answers
You need to replace the convergence IC in your tv . It is due to bad convergence . You can get IC from partstore.com
  • SAM ANDERSON Jan 07, 2009
    It will cost you around $ 20 to buy the IC .
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Ws-65909 picture and sound are fuzzy, will a new power supply fix it???
It does not sound like a power supply problem. Most of the boards for this set are no longer available from Mitsubishi.
The most common problem these sets have is called convergence. Go into the customer menu with the Mitsubishi remote and select convergence--enter the "advanced" and look at the grid of lines (set will have on screen instructions for this) Let me know more exactly what your picture looks like.
If you need more help or advice rate this solution as I do this here for Free. Reply here and I will help you.
Regards, SD TECH
Nov 27, 2009 | Mitsubishi WS-65909 65" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
WS-65907 picture problem
Try resoldering the convergence ICs mitsubishi has been known to be a little stingy on the convergence IC solder in the past.
May 15, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-65909
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Distorted picture
It seems you have a loose conection in the Horizontal deflection circuit,I will start checking the horizontal driver transformer then any overheated areas in the power supply and overall chassis.If you are familiar with tv service you know where to look but if you are not be safe and call for help,try no to use the set or the problem will be worst.
Sep 26, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
