Question about GE DBSR453EBWW Electric Dryer
Dryer hums When I turn the start knob, the dryer only hums, drum does not turn. Belt is not broken. What could the problem be?
  • Anonymous Mar 17, 2014
    broken dryer knob
  • 6 Answers
First, can you turn the drum by hand easily in both directions, if yes, then you have a bad motor, if no...unplug the dryer. open the door and in the opening on the top edge there are two screws, remove these. The top on the dryer can now be removed. Inside the top there are two screws that hold the front to the cabinet, remove these. The front can now be removed and rotated to the side. You can now see the fan (blower), make sure there in nothing caught in it, if there isn't, you probably have a bad motor
Posted on Jan 07, 2009
    Genius:
  • 2,920 Answers
The motor could be bound up or going out on it. you would need to take it apart and see if theres something binding it up
How to fix so it turns on and drys instead of humming and Pausing
If the dryer is I humming but the drum is not turning then the motor is turning but the belt is not attached, it is probably broken and needs a new belt. if your belt is intact then your motor or start capacitor is bad.
Aug 09, 2014 | Electrolux Frigidaire Affinity AGQ8700FE...
Have a late model Kenmore Gas Dryer, It won't start, when I turn the start knob it just hums. Ideas?
if the motor is humming you have a broken belt that drives the drum around
Mar 17, 2011 | Kenmore Dryers
When you press start on my dryer is is making a humming noise but will not come on
On the info provided, it may be the drum belt has broken and the motor is not able to turn the drum. The humming you hear is most likely the motor turning as it should, but due to the broken belt, the motor is not able to turn the drum.
Jan 22, 2011 | Kenmore Dryers
DWSR463EGWW Electric Dryer: The dryer drum won't turn. I can turn it manually ...
It sounds like the belt that drives the drum may be broken
May 03, 2010 | Dryers
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Dryer will not start
I had the same problem and this is how I fixed it ,,, i did a comfortor ,very heavy when wet .....next day i tried to do a new load ...when I turned start button all i got was a hum... I removed screws just inside door at top of lip this releases top of dryer,,,, exposing drum i rotated drum clockwise to check condition of belt ....looked good ....mine is 7 yrs old ...to soon to be motor problem ....so while turning drum i held start button on and finally motor kicked in and this solved my problem...you might be able to accomplish this without taking of panel ..though you wont be able to see belt ....by turning the drum from inside dryer while someone else turns on start button
Oct 25, 2008 | GE Profile Prodigy DPSR513GA Dryer
Clothes dryer
dryer won't run, but hot air blow and humming when turned on
Belt is off, idler is off or broken. Replace the belt and idler. Make sure it is installed correctly with tension on the belt. It will take care of your problem
When I try and start my ge dbb3300eaoww dryer it buzzes as if it wants to start if I spin it with my hand it will work. I put a new belt on it and it does the same thing.
Motor start switch is bad. This is typically replaceable with out replacing the motor.
Will take care of the problem.
My drum will sometimes stop turning in the middle of a cycle, and the motor just hums. I pause the dryer, open the door, rotate the drum, unplug and plug the electrical, and then it will usually complete the cycle. Does that mean the belt is "occasionally" slipping? How do I check this?
Replace the belt. It has stretched to the point it no longer can carry the load. Should consider replacing the idler at the same time. This will take care of the problem.
Sep 15, 2007 | Dryers
GE DBSR453EBWW Electric Dryer Logo
102 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
