Question about Eureka 4386AT Upright Vacuum
Vaccuum stopped running
I had just replaced the belt and vaccuum worked great. Then, after a few minutes it just quit. Instructions on back of machine said to unplug immediately and look into manual, which I do not have. What do you suspect the problem to be? Thanks
    Sergeant:
  • 351 Answers
Belt jumped off beater bar and jammed it! Disconnect belt, does imotor run. If yes, reconnect belt turning beater bar by hand to see if it is smooth. Carefully, reassemble and run it!
Posted on May 30, 2007
SOURCE:
For the first two years our DC07 worked great, but then it would run for a few minutes and then just quit. After a few minutes it would start again and then quit. We washed the filters and checked the air...
I'm sorry to hear about the difficulties you're having with your DC07. Someone will be in touch to discuss this further and help you resolve the issue shortly.
Best wishes,
Jack
Dyson Online Customer Support
Nov 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
Bar not spinning
The belt is probably worn or stretched. Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Nov 19, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My fusion just stopped. i was vaccuuming and it
One item to check is this: This unit has a temperature overheat device.
Unplug the unit for 20 minutes, then plug in and turn on the switch. If there was a blockage in the hose/cup/filters, this could cause the overheating.
If this does not resolve the problem, it will need disassembled and checked with a continuity meter to determine the component that failed (motor, switch, cord, or TCO)
Oct 25, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Kenmore 26082 Canister Vacuum Shuts off constantly. When Im vaccuuming maybe about 5 minutes later it shuts off. Then give it a few minutes later it turns back on. Whats the problem with this vaccuum
You could have a clog in the hose. Also check your filters, if you haven't changed them in a while, that could be what's suffocating your motor
Aug 19, 2009 | Vacuums
The brush stopped spinning on my Dyson upright
hi there'
common possible defective is that motor is not functioning,several factors can be check if you have a knowledge on electrical and motor
circuit you can easily diagnose your problem on your vacuum.
check the switch by your multi tester,if there is a continuinity resistance using multi tester.if no continuity replaced switch
check the carbon brush of the motor if worn out, replace two pcs. of carbon mounted inside the motor casing
you can check also the continuity of electrical cord and plug.replace if if plug and electrical cord is defective.
finally the motor has winding coil,at both end of coil of motor check the continuity,there are two coils of the motor.if burn out replace motor w/ two pcs. of carbon brush.
besure to unplug the vacuum before doing
this and this should be done by qualified technician on your service center.have a nice day.rate my fix.thank's a lot
Jun 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush won't spin on my Hoover Mach 5
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
Oct 12, 2008 | Hoover U5194-900 Mach5 Multi-Chamber...
Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Jan 23, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Hoover fusion plus cyclonic upright vacuum
While I'm having a different problem, the problem you guys are experiencing can easily be fixed by cleaning the two internal filters. My vacuum did the same thing, just stopped running mid-stream. Remove the main filter cup. Look inside the cavity of the vacuum and you'll see a grey bar at the bottom of the cavity, pull this up and you'll find the first of two washable filters. Just rinse it under warm water squeezing as you rinse until the water runs clear. The roll the filter in a few paper towels or towel and unroll, reroll until completely dry - should only take a few minutes. Then, look in the same cavity except up top there is another filter which seems to be hidden. The back wall of the inside cavity will guide you to these filters as well. You will be amazed by the difference cleaning these will make in the suction power of your vacuum. Also, if you remove the belt cover and clean out the hose in this area it will improve suction as well. Hope this helps. Now, if I could just get the darn belt back on mine. First belt smoked and popped. Bought replacement belt, smoked and popped within seconds... HELP!!!
Dec 16, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Eureka 4386AT Upright Vacuum Logo
166 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
