Question about Intel D865GBF Motherboard
Ram not working with motherboard
I have a intel D865GBF motherboard and bought some Samsung ram ddr 1gb pc3200 and it wont post. if i put the new ram in slot A dim 0 slot and my old ram in (512mb ddr 400mh) slot B dim 0 slot it will post with proper ram size let me get into bios but wont load windows at all ???? help
  • velvet_stran Jan 07, 2009
    the motherboard can support dual channel and single channel pulled a stick out of friends pc it was pc3200 ddr 1g and it poste.. but my new ram would not post in his even sooo confused lol ..
  • velvet_stran Jan 08, 2009
    yeah called to replace there telling me its high density ram and my motherboard only supports low density ram not sure about that going to have to look that one up but i can exchange it just going to cost me time lol
    Scholar:
  • 65 Answers
Hi
Check if your motherboard only supports only dual channel interleaved memory from the manual because it might be the main issue of your problem. Also DO NOT plug in the 512 MB ram you have over there. If it is ok to have one Slot empty then there should be no reason why it should not POST properly. Before jumping to conclusions that the RAM is faulty. Make sure that you REMOVE any overclocking you might have on the system. Some RAM won't post wihen the CPU clock and multiplier are not standard. Also it could help if you load FAIL SAFE settings in the BIOS until you determine the proper cause of the problem.
Hope that this helps :) (please rate thanks)
Posted on Jan 07, 2009
  • 1 more comment
  • Alcatrazx
    Alcatrazx Jan 07, 2009
    From what you're saying it must be the RAM then can you get it replaced?
  • Alcatrazx
    Alcatrazx Jan 10, 2009
    What a CHEEK they have! If that is the case sell it off on ebay....
  • Alcatrazx
    Sorry to comment again but on second thought .... I think the high - low density issue is a load of **** so be careful!
Hello! I have a D101GGC motherboard and I want to upgrade my memory, I mean now i have two RAMs at 250MB and i bought one DDR 1GB PC3200 400MHZ CL3 KINGMAX MPXD4. The problem is that the PC doesn't...
Please check the speed in MHZ of old RAM and New 1GB RAM.
Some times if speed wont match this problem occur.
Remove old RAMs and add only 1GB RAM and start the system.
I hope it will help you.
Thanks for using FixYa.
May 31, 2011 | Intel D101GGC Motherboard
The ram is not work
remove your ram, clean the ram terminal using an eraser then put it back properly. Note: hold the ram at both ends.. voykid.jpg
Apr 29, 2011 | Samsung 1GB kit (512MBX2) PC3200 400MHz...
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
My desktop has intel 845gvsr board, n have a 256 mb ram installed on it. i want to upgrade it to 1gb what kind of ram should i go for
Each memory slot can hold DDR PC2700 or DDR PC3200 Non-ECC, Non-buffered RAM with a maximum of 1GB per slot.
You can refer to this site for more info on your RAM and motherboard.
http://www.crucial.com/store/listparts.aspx?model=D845GVSR
Thanks for using Fixya.
Feb 23, 2010 | Intel D845GVSR Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Hi can u tell me how to choose RAM for my motherboard?D865gbf board, need to upgrade memory.
this motherboard supports Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100)
the limit is 4gb RAM
Jul 13, 2009 | Intel D865GBF Motherboard
Can i use DDR2 RAM in intel 865GBF motherboard?
Your motherboard can hold:
Each memory slot can hold DDR PC2700, DDR PC3200 with a maximum of 1GB per slot.
So, no, you cannot use DDR2, you can only use DDR with the specs above.
Jun 13, 2009 | Intel D865GBF Motherboard
NO ! you can only use DDR 1 ram (266Mhz,333Mhz,400Mhz) speeds only
Mar 30, 2008 | Intel D865GBF Motherboard
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
Intel D865GBF Motherboard Logo
206 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
