Question about Microsoft Xbox 360 Console
2 red rings could the hard drive have anything to do with it
And could it be dust
    Scholar:
  • 30 Answers
I suggest you to try DIY Guide that wil explain solving the 2 flashing red lights along with some other common problems of Xbox like Disc Read Error, No Video Problem and most famous RROD. Even a novice can solve the problem with the help of step by step process given at the guide. I think it's worth trying. If you try this method, you won't have to wait for 3-4 weeks and you can enjoy your gaming experience within 2 hours, once you try this guide.
Posted on Mar 07, 2009
The unit will switch on then clicks around the VCR, DVD and the HDD, then switches itself off!
I have had this problem. Today I unplugged the machine completely and left it for about an hour (to make sure the power supply was drained). Then I unscrewed the little black case screws (small cross-head screwdriver) and lifted off the lid. Does anything seem wrong? Dead mice etc.? See if there is much dust inside, especially around the fan at the back right. If there is, then blow out what you can (with an air dust can - not spitty breath!).
Without touching ANYTHING in the case, plug the machine in and switch on with the remote. Select DVD immediately and see what it does. Does it seem OK? If so leave it for as long as you can before switching to HDD. If the hard-drive makes a noise it's probably on the way out. The hard drive can be replaced (SATA drive).
If there is no joy from the machine after switching on (flashing lights etc.) then give Toshiba a ring about the possibility of a repair.
Good luck.
Jun 24, 2013 | Toshiba RDXV59DTKB Rd Xv59dtKB Dvd...
I have one red light I took the hard drive off cleaned off the dust took the face plate off and cleaned the dust off of that now I can't get it to turn on.
Often this is not a sign of the red ring of death, so I believe you are in luck. Try to make suree all of your power cords are connected, also unplug them and plug them back in. Also try to remove your hard drive and put it back in. Hope this helps.
Mar 08, 2011 | Microsoft Xbox 360 Console
Hard drive has red ring can we replace with any hard drive?
...HDD has red ring? No, you cannot replace it with ANY hard drive, it needs to be a microsoft xbox 360 hard drive
Dec 30, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Red ring of death and freezing
How many segments show in the RROD? It may be that the unit is overheating. You can open the case and remove the shielding until the heat sink (large aluminum fins) is visible. The outer case opens much like a clamshell once the case screws and gray plastic end pieces are removed. There is one not-so-obvious case screw through the middle from the bottom which makes the inner components hard to access. Take your time and do not force anything. If the heat sink is dusty, blow it off with compressed air or dust-off and reassemble. This will probably stop the freezing. It is advisable to keep the unit is a cool, dust and smoke-free environment if possible to prevent this problem in the future.
Nov 17, 2009 | Microsoft Xbox 360 Console
4 lights on the front ring of console flashing red. Checked AV connections O.K. and power is on.
This is called the Red Rings of Death. You need to either get a new xbox, or if your warranty is still good, send it in to microsoft so they can fix it.
Nov 13, 2009 | Microsoft Xbox 360 Console
I just purchased COD4-2 and while playing the game on my xbox elite, it freezes. I thought that it might be the game, but tried another one and the same thing happened. How do I fix this problem. there is...
Sounds like your console is over heating. Take an air pressure can that you can purchase at a local store (RadioShack, Home Depot, Office Max/Depot) Spray the vents to clear out the dust. Do this outside.
Make sure to clean it as best you can with the air pressure can, you need to get all of the dust out of there.
This can also be a warning sign that your console might soon red ring so be careful. Also make sure you got some free hard drive space?
Nov 11, 2009 | Microsoft Xbox 360 Elite Console
3 red ring and power supply
First try removing any accessories (for eg HD drive, hard drive or network adaptor) from the console and turn on 360. Plug each device back in one by one and turn on to check which device possibly causing the problem.
You should also try using another 360 AV cable sometimes this is the culprit.
If the above methods made no difference then the Xbox 360 might be overheating and which will eventually lead to RROD (Red Ring Of Death - 3 red ligthts) or E74 error message (1 red light) indicating repair.
Check whether your Xbox 360 console is still in warranty as its most likely Microsofts fault not yours and they should repair it for free
You can buy the repair kit off ebay from £4 - £7 and carry out the repairs yourself with plenty of Youtube videos on the net just google it or if dont dont feel confident i can repair for you.
If this helps please vote...thankyou!
Aug 13, 2009 | Microsoft Xbox 360 Console
Game freezes after playing for a while but no red rings appear
Games freeze for two reasons. Overheating and the hard drive locking up. If you have your games installed, you most likely eliminated the overheating problem.
Since you are not getting Red Ring, it probably isn't overheating. That leaves the hard drive. Turn of the console and unplug it. Remove the hard drive. Now is a good time to clean any dust from the connectors or vents. Reattach and play. Some games like Fable 2, Fallout 3, and others are more prone to freezing when accessing the hard drive that others. If it is freezing more times than not, you have an issue with the hard drive.
Jun 09, 2009 | Microsoft Xbox 360 Console
Red ring of death
It means "general hardware failure", so it could be any number of things. Its like a check engine light except when it comes on , it means something doesnt work. The only way to fix it is to send it off to xbox. Call 18004MYXBOX and they will send you a prepaid shipping label and a box and will get it back to you within a few weeks. Your xbox should be covered under microsoft's warranty so it shouldnt cost you anything. Removing the hard drive wont fix anything because the hard drive isnt needed for the xbox to operate, so if it failed the xbox would be fine but wouldnt be able to retrieve the data off it.
Oct 20, 2008 | Microsoft Xbox 360 Console
Original Microsoft Xbox Problem
mi xbox me pide asistencia tecnica y ya no lee los discos
Jul 16, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
