Question about HP DeskJet 812c InkJet Printer
Printer error message
I keep getting an out of paper error. I have paper, the light isn't blinking on my printer; how do I get my computer to recognize that it's ok to print.
  • 3 more comments
  • Anonymous Dec 08, 2007
    when the paper finshfrom the printer when we feed the printer with antother paper it printed smoe sample and words and continuing many paper and affter that return back to main printer opject
  • Anonymous Dec 31, 2007
    paper in but displays out of paper red light on all the time also green printer light flashing
  • Anonymous Feb 08, 2008
    Try to copy email or email attachment and get error message that I am out of paper when there is paper in the tray.
  • stanlau68 Jun 21, 2008
    paper in the input tray feeds part way and stops. sounds like it is trying to print but the paper does not move. then it shows an error message that it's out of paper.
  • tom_brand Jul 18, 2008
    randomly the printer shows error message :"printer out of paper" with orange light blinking and stops printing although there is enough paper in the tray. In case the printer is supposed to print several pages it frequently prints the first page or a few pages and then stops because it indicates that it is out of paper. Some times after disconnecting the printer and then reconnecting the printer works again but frequently it does not help.
    Genius:
  • 2,985 Answers
Will it not feed a sheet of paper? The feed track of an HP is very convoluted. Take paper tray out and try a vacuum cleaner suck to ensure no paper debris is sticking somewhere, 'Knock up' the paper pile and ensure it is fully inserted in the tray. Turn printer off then on See what happens. Also take a look at www.fixyourownprinter.com
Posted on May 28, 2007
Also try checking the paper size on the left hand side of the paper tray if this is any of the hp 4*** series. make sure it is set to the same size paper that you have set to in the paper handeling menu
Posted on Mar 18, 2008
2 unit to let : F1.133A & F1.135
Contact No 012-3086838
YM Thong
Posted on Dec 05, 2007
Check paper sensor in the feed track just above paper tray if it is well placed from jkilungya@yahoo.com
Posted on Sep 18, 2007
  • 4 Answers
If u get a error of out of paper instand of u have paper in try. if u get a error from tray two then u need to clean paper sensor pcb board which was right hand side of the printer in below four plate there and if then also problem was not slove then u need to replace the senser pcb board and if u get a error from tray one then clean the paper senser there and check the senser cannection and if problem not sloved then u chnage p.i unit of the printer
Posted on Sep 09, 2007
2 Suggested Answers
pineworks
  • 4293 Answers
SOURCE: paper jam error message..no jam
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 15, 2010
MG3260. trying to set up and keep getting P2 error message. tried turn off both power cord and switch. still the same
not picking up ink cartraiges, is the plastic sticker peice off the ink cartridges? are they lined up right in the printer, do you have enough paper in the machine for it to register.
Feb 09, 2013 | Canon PIXMA Office Equipment & Supplies
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
Blinking Light with no cartridge problems My HP Deskjet D1460 has its light blinking with no status messages that suggests an error. However, I am unable to print as the light keeps blinking. Could...
Hi
this problem has many reasons :
- no paper or error in paper feed sensor.
- jammed paper in printer thats prevent it continue.
- try to disconnect usb cable and if its stop lighting reinstall the driver
- else you must search about hardware errors
Apr 26, 2011 | HP DeskJet D1460 InkJet Printer
The error light came on and I don't know whats wrong
What is the error light
Step one: Identify the specific printing problemIf your All-in-One won't print, first you need to identify the specific issue or symptom. What exactly happens when you try to print? Do you see an error message or do the lights on the printer start blinking (flashing)? Does nothing happen at all? Follow these steps to identify your unique printing issue before troubleshooting. If you can identify a symptom based one of these methods, make a note of the symptom, and then continue to the next step. Method one: Look for blinking lightsLook for any blinking lights on the front or top of the All-in-One. Sometimes just the power button can blink, or a small indicator light on the printer can blink, or a combination of buttons can blink all at once. Example indicator lights on the printer Attention lights Wireless indicator light Cartridge lights Error Lights c01890693.gif c01890694.gif c01890695.gif c01890697.gif c01890698.gif c01890699.gif c01890700.gif c01890701.gif Example blinking lights patterns
c01890702.gif Method two: Look for error messagesPrinting problems are usually accompanied by an error message of some sort, usually on the control panel display (if your All-in-One has one), or on your computer monitor. Check both places for specific error messages. Error messages might or might not be accompanied by an icon representing the error. Following are some examples of error messages you might see on your computer screen or control panel display.
  • c01890703.gif 'Printer is Offline '
  • c01890704.gif 'Align Cartridges '
  • c01890705.gif 'E ' (error condition)
  • c01890706.gif 'Document(s) pending ' (Roll your mouse over the product icon in the lower-right corner of the computer screen.)
Jan 16, 2010 | HP DeskJet F380 All-In-One Printer
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
May 11, 2009 | Office Equipment & Supplies
I believe this is normal with HP deskjets. I have a different model but HP deskjet 3740, which also gives a blinking light when there is a pending print job and or printer has run out of paper. I usually get rid of this problem by putting some paper and most importantly removing and re-plugging the printer power cord (which does a basic power reset on the printer and causes a refresh of pending print jobs). I hope this works for you too.
Jan 27, 2009 | HP DeskJet D1460 InkJet Printer
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
HP DeskJet 812c InkJet Printer Logo
593 people viewed this question
Clive
Clive
