FixYa.com
Tags:
Parkinson Cowan SG320 Gas Kitchen Range
My gas oven flame (by 3 users)
posted by catnic on May 28, 2007
my parkinson cowan oven is not reaching the right temperature.on first ignition the flame no longer gets high it stays low as if the oven has got to the correct temp,but its only warm
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 05, 2008
PARKINSON COWAN sig320sN2 NOT GETTINGB HOT AFTER IGNITION ACCORDING TO PHONE ADVICE FORM GAS FITTER COULD BE FAIL SAFE DEVICE ?
Comment by Guest, posted on Dec 18, 2007
I have the same problem. Both replies seem plausible but how do I fix it in time to cook the Christmas Turkey please?
Best Solution
posted on Jul 07, 2007
FixYa! (100)
ali88
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 01, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
the flame failure device( FFD) may have malfunctioned,not allowing full volume of gas through to the burner.This is a safety feature, preventing full gas pressure to the oven straight away.
Solution #3
posted on Jul 18, 2008
Not Rated (0)
jophnnyfixit
Rating: 0%, 0 votes
If it is a Flame Failure Device malfunction ( now termed Flame Supervision Device) then as long as you have a flame the FFD/FSD control will be over-ridden if you leave the oven on a high setting (say Gas Mark 7) for about 10/15 minutes. Any malfunction should temporarily correct itself and you will be able to cook safely at the correct temperature but this will probably be a requirement every time you want to use the oven. The FFD/FSD is a CORGI required component and therefore very important from a safety aspect so I called in a CORGI registered plumber to give me a quote. The quote was nearly as high as the cost of a new oven so I just bought a new oven with a warranty.
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
Dear Help, I have recently
Dear Help, I have recently... Answer This...
Kitchen Ranges
our viking vgsc305-4bd-ss keeps...
our viking vgsc305-4bd-ss keeps... Answer This...
Kitchen Ranges
Need instructions for a...
Need instructions for a... Answer This...
Kitchen Ranges
Hot plate wont alter heat,
Hot plate wont alter heat,... Answer This...
gas grill
when i light the grill it... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
