Question about JVC AV-27530 27" TV
JVC I'art flatscreen TV remote doesn't work
I changed the batteries in the remote and it still didn't work. I bought a universal remote and it won't work with the set either. The set is only a couple of years old.
    Problem Solver:
  • 17 Answers
This maybe a sticky one.
#1. Original remote may have something spilled in it or may have dirty battery contacts.
First check battery contacts and make sure it's not corroded. Clean with small brush and baking soda. Let dry thouroughly and replace with fresh batteries.
If this isn't the problem or you tried this, then move on.
Next, Get these materials. A cloth, 50% amonia and 50% water sulution two small blad pocket knife and a philips head screwdriver.
Some remotes will have screws holding remote covers and internal board and others do not. If your remote have screws, remove them all. If not, then start prying your remote apart with your pocket knives. Do so very carefully as not to damage anything inside.
Next, lay down remote button facing down, and remove circuit board. Now, take note of rubber button pad(s) position(s) and remove them. Place these pads in your water - amonia solution.
Clean all cntacts and rubber pads, and remote housing. Now before reassembling remote, look at the IR lamp at end of board. Look underside and notice solder joints. Wriggle lamp and see if solder joints move. If so, have this resoldered. Now reassemble remote and give this a try.
#2) Codes may have not been entered right with your new universal remote. Go through all codes again just to be sure.
#3) IR receiver in set maybe damaged or not receiving power to it or the microproccessor has quit responding to the remote commands. Have a good technician check into it if problem is evident that your set has simply stopped responding to remotes.
Good luck,
Jason.
Posted on Jan 09, 2009
My TV remote doesn't work. I changed the batteries but that didn't solve the problem.
The remote can be tested and Radio Shack and most repair shops have a simple card for testing---point the remote at the card and press buttons and the strip on the card either lights up or not.
Depending on the problem most remotes are fixable.
Stay away from "Universals" as they are usually trouble.
If batteries and remote test good the set has a receiver for the infrared signal the remote sends-
95% of the time it is the remote and not the receiver or set.
A precise model number would tell me of common issues with your set including the remote.
Mar 14, 2012 | Televison & Video
Remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Nov 14, 2011 | Televison & Video
32'' flatscreen (CRT) JVC I'Art tv will not turn on
I remember Jvc put out a service document about changing 2 transistors in the power supply..they are surface mount on the solder side of the pcb. You might not find the parts anymore unless your very tech saavy. Sorry man..
Jul 22, 2017 | JVC Televison & Video
The remote for my 20: LCD TV has stopped working, i have changed out the batteries and even bought a new one but still nothing. What should i do?
there are several things to try.. first, isolate the source of the problem... get a universal remote (borrow one from a friend if you don't have one--get the instructions, too)...then program it for your tv...if the UR doesn't work, then there is a problem with either the tv or its remote sensor...try the troubleshooting guide for the tv or call the customer service line (ask if there are similar probs going around for that model..you might get some special incentive to quit ****, if so..) If it DOES work, then it's your remote...best thing to do is make sure that the batts are good (which you did....but make sure you didn't get a fresh set of batteries from the same bad lot - it happens)...then check to make sure that the connections for the batteries are not missing, broken, or bent.. Look for corrosion, loose wires, solder gone...anything you can see which might cause your problem...Nothing visible? send it back..or try to exchange it at the store you bought it from, if it's a currently selling model Hope that helps you
Feb 22, 2010 | Televison & Video
Channels won't change on tv with remote or manually
hi,you need to auto search first your your t.v set if nothing happen possible defect is the tuner.
Aug 03, 2009 | JVC LT-32P679 32 in. LCD TV
LG flatscreen TV
HI,
The only solution will be to buy a original remote for the tv and for that you'll have to contact the manufacture.
If you need anymore help let me know..
Jun 19, 2008 | Televison & Video
Citizen house tv that has a 'lock' logo on screen
The TV has been 'Locked'. To unlock it press the DISP button for 4 seconds. Since you have a universal remote and there is no way to determine which button is the DISP button try holding each button on the universal remote for 4 seconds until, hopefully, you find the correct one.
Mar 10, 2008 | Televison & Video
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
JVC AV-27530 27" TV Logo
557 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
