Question about IBM ThinkPad R40 2722 Notebook
Ibm thinkpad r40 laptop just installed new harddrive, powers up no operating system found..... reorder harddrive, still no change setup and booted from cd, no change when placing windows xp cd will runcouple secs and then just stops.tried different cds troubleshoot. how do i know is cd/dvd rom is defective? help, thanks a lot
  • jharris919 Jan 07, 2009
    i tried to install me and xp will not read disk i guess.
    keeps saying that operating system not found new hardrive but will not cd install.and no no floppy drive.help.
    wonder if bios has to be updated ?
  • Mouin Aboulhosn May 11, 2010
    two questions:
    Did you install an operating system on the hard drive because they dont come pre-installed.
    also
    do you have a floppy drive?
  • IBM Master
  • 32,281 Answers
The problem is that you need to boot up the laptop with the CD as the first boot device so you can then install Windows XP.
If you press F12 a boot up you will get a list of alternate boot devices oher than the hard disk as the first boot device, which was set up in the BIOS. Select the CD as the first boot device and when prompted press the space bar to start the CD.
Posted on Jan 07, 2009
IBM R40 PXE-MOF:exiting boot agent opreating system not found?
This appears to be an indication of a failed hard drive. During the bootup process, your computer looks for bootable (accessible) devices including your hard drive, external drives (if any) and then any other possible mediums like network attached resources. If the hard drive is not available then this would explain your situation.
Aug 25, 2012 | IBM ThinkPad R40 2723 Notebook
My laptop will not boot up, instead it goes directly into a screen I haven't seen before and says, "Operating System not found"
usually this means that the previously installed windows/linux operating system is corrupted....best to re-install operating system via disc windows/linux....so that it replaces corrupted informatiom/instructions on hard drive....if you have files you want to keep then dont do a format on install as you will definately lose them......
Jun 12, 2010 | IBM ThinkPad R40 2722 Notebook
My computer t-40 laptop starts to boot but then shows pxe-e61 media cable disconected pxe-mof intel boot agent,I bought this laptop used ,I was told that it was tring to boot from a net instead of...
Hi there, please try this trobuleshooting steps. after you push the power button quickly tap the F12 key until you reached too boot options menu. once you are already at the menu, select you Hard drive usually harddrive represent as model e.g WDC **** it means western digital. once you slected the harddrive your computer should boot now to your Harddrive. if else fails, waht you need now is to check if you cmputer was able to detect you harddrive. restart the computer then this time keep tapping the F1 key to enter the utility setup. once inside the setup check your system information under internal HDD if motherboard can detect your harddrive. if yes, then all you need to do there is to use the recovery cd that came with the system then boot your computer from the cd rom then install you windows. If not, then you have to contct your manufacturer. that could be a defective harddrive. please let me know if you need more help.
thanks
Apr 07, 2010 | IBM ThinkPad T40 2373 Notebook
Bought a ibm r40 at a auction but has no operating system
Get into setup(probably F2 at start up) and check what hard drive it has, if any.Then, does it have a floppy drive,or a CD drive? Also, if it has a hard drive, it is possible to connect to another computer and format, and install windows. Good luck.
Feb 21, 2010 | IBM ThinkPad R40 2897 Notebook
I just bought a used ibm think pad laptop
Hi there.
If you have just bought the laptop chances are the operating has been removed to you cannot see any data that used to be on it, you need to go and purchase a windows OS that the laptop was built for (i'm guessing XP) and re-install the operating system again.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | IBM ThinkPad R40 2681
IBM ThinkPad R40 No PowerUp
If the the ram is the problem of your system, there should be a power on light on the system. indicating that some of the component of the system is not working correctly. But since you mentioned there is no light, it is the possibility that the problem is the motherboard itself.
Feb 26, 2009 | IBM ThinkPad R40 2722 Notebook
IBM R40 hardware malfunction
press F1 on boot up and get into the bios, reset defaults and then chane the boot order to the CD/ROM, save changes, reboot and you should be able to install XP
hope this works
kind regards
Nov 18, 2008 | IBM ThinkPad R40 2897 Notebook
you can buy ext. hd case to back up your things, if your ibm can't boot then might be your motherboard got problem or graphic card.
Sep 08, 2008 | IBM ThinkPad R40 2897 Notebook
Ibm thinkpad r40
I need the instruction on how to install a replacement DVD/CD player on my IBM R40 thinkpad Laptop.
Thanks,
Moses
Feb 22, 2008 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
Can't boot my Thinkpad R40
its ok pat sounds like mobo power ships not doing thers jobs nomore ok would have to buy new motherbord ok thx nick
Feb 06, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 2722 Notebook Logo
281 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
