Question about Cozy (W352E) Heater
Thermostat not communicating with COZY heater
Can you please walk us through some troubleshooting to help get the thermostat to concect with our heater?
  • msgshtgn May 11, 2010
    your problem might not be the thermostat it might be a dirty pilot or a weak thermopile... check your milivolt reading at the valve you should have at least 400 with an open circut 250 closed,,,, or te valve won't open.... if you have a dirty pilot you can tell the flame will look lazy and yellow... to clean it you must remove the orifice and clean it with a tiny wire or wd40.....do not reem orifice to big it needs to be tiny or you;ll have to replace it...
    President:
  • 1,515 Answers
Yes, I can walk you through the steps to see if the T-stat is faulty or not. Just follow my steps.Make sure that 1st, the pilot is on. If not, it will not send signal to T-stat. So, if it is on, go to the T-stat. You will need a small screw driver maybe slotted or phillips. Remove the front cover. You will now be looking at the 2nd part which is the thermostat. There will be several screws on it spread around that you will need to loosen all the way up. Note: No danger of shock as it is a millivlot system, No power source only less then a volt. Anyway, remove this section. You will now see the sub-base and wires. For a wall furnace you should have only 2 wires, a red and a white unless it was changed years ago. If you have a piece of insulated wire lying around, even speaker wire or scrap electrical wire is what you will need. Once you get this and both ends are bare, touch across the two terminals and hold them there. It will fire right up if the heater is ok, pilot on and now main burners on. If this happens, you will need a new thermostat.You have just by-passed it to check the heater and if it came on we know the T-stat is faulty, very easy. If this was it, go to a hardware store and get a heat stat milivolt only! Even though a 24 volt programmable heat/cool stat will work, it will start causing problems, so please don't let them talk you into this! Trust me on this. If the pilot was on and it didn't fire up, check wiring at gas valve and make sure it is tight. Up above toward the top of furnace, if it did not fire only, you can remove the entire cover, may have 2 screws at bottom and will lift out of a grove at top to remove, You should see a round switch with a blk wire in and out the other side. This is a high limit safety that will shut off furnace if there is a problem and the heater keeps running when you are not home. Its job will be to open contacts to shut down main gas vale to save you're home. If you have done all I have asked you to do, and nothing, put t-stat back together, make sure pilot is lit and touch wire on this limit from one side to other. If it fires up, the limit is bad. This you will need to buy at a appliance parts store. I am 99.99% sure it is the stat. Please keep me posted by my user name. Good Luck,
Shastalaker7
PS, If all fails, and pilot does stay on, you will last but not least have a faulty (MGV) :((
Posted on Dec 18, 2009
  • Robert Horton
    Robert Horton Dec 18, 2009
    Hi, It is possible it could be the 750 thermopile generator, but if the pilot does stay lit, the generator is sending the correct amount of voltage to the t-stat and gas valve.
    Shastalaker7
Cozy wall heater. pilot stays on heater will go on once in a while by moving thermostat up. will run for about a minute then won't react to thermostat when i try to get it going again.
Shut the power off. Pull the thermostat off the wall and jumper the two wires, meaning put them together. Turn the power back on and if the heater works fine its in the thermostat
Dec 06, 2017 | Cozy Heating & Cooling
Cozy wall furnace (propane) does not respond to thermostat. The pilot is lit. Furnace is 3 yrs. old and rarely works. The wire to thermostat is 20 feet.
Try jumping the two thermostat wires together to see if the heater starts. If so, replace your thermostat. If not, jump the two terminals where the thermosta twires attach to the furnace. If it starts, you have a bad thermostat wire or connection.
Jan 30, 2010 | Cozy (W352E) Heater
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
How do you hook up a millvolt thermostat to a cozy model vcr351
If the cozy is a milivolt system then on the gas valve there should be three terminals.. th/tr/thtr the thermopile(wich creates the milivolts) goes to the tr terminals.. your thermostat goes to the th....
Dec 22, 2008 | Cozy (W352E) Heater
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Cozy Heater will not turn on from thermostat in the morning
no more than 20 feet of statr wire allowed and make sure the stat you have is for a millivolt system.
Dec 03, 2008 | Cozy Enclosed Front Console Heater 70,000...
My Cozy heater does not respond on the thermostat control
Make sure you have a stat that is for a millivolt system, if the stat you have has 24v on it wrong one, need to purchase at a heating wholesaler home depot lowes do not carry them.The stat should have mv for millivolts on the box or stat.
Nov 23, 2008 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
340 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
