Question about Compaq Presario 5000 PC Desktop
Monitor does not come on
Put in new ram. Now monitor will not come on. No beping warning from ram. Change ram back to normal still monitor will not respond.
  • Alex Smallwood
    Alex Smallwood May 11, 2010
    Check All Connections
    Remove CMOS Battery To Reset BIOS
    Try A Different Power Supply
    Remove And Refit Graphics Card
    Try Another Graphics Card
    If Using Graphics Card Try Onboard Video and vice versa
    Does anything power up at all? You might need a new power supply if nothing comes on
    Also check the wall socket , plug something else like a lmap in and see if that works.
    Ive also repaired problems like this where the RAM socket itself was actually burnt. Check for any burns on both the RAM and the RAM scoket aswell and if there is a burn on the socket , dont use that socket.
  • Adam Jones May 11, 2010
    Is it onboard video or video card? Try reseating the card if there is one. Also clear the bios either by jumper or remove the battery for a second. Make sure the power is disconnected.
    Scholar:
  • 111 Answers
Swap your other ram card into the other slot to assure the ram slot has not died do this by leaving your new card out and swapping your current one into the other slot examine if it boots as normal.
In no way do I aim to insult your intelligence but have you ensured that the new RAM is the right type? e.g. DDR2
Posted on Jan 07, 2009
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
When I turn on the computer, the monitor massage states there is no communication signal with the computer
Warning: Before Doing the Below Steps don't forget to Unplug the Power cable, monitor cable, keyboard and mouse and any other device connected to your computer.
Do the following Steps.
Step 1: Open the PC case(not your monitir)
Step 2: Locate the CMOS battery on the mother board.
Step3: Remove the Battery and leave it for 4-5min, now put the battery back in its proper place.
After doing above steps now you can connect the power cable, VGA cable, keyboard,mouse etc... and switch on the computer and see if you are able to get display. If still you find the same problem you can try removing RAM from RAM bank and clean it with a brush or a cloth ,both RAM and RAM Bank. Now Put back the RAM and switch on the computer.
All the Best and Hope it will work for you.
Jul 11, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
SyncMaster 793DF 17" CRT Monitor: monitor makes high pitch noise...
With a piece of wood or plastic hit the flyback with the monitor turned on. If you note some change in the noise. Replace the flyback.
Normally, it is the cause of the noise.
Warning: High Voltage!! Do at your own risk!!!!!!
Best regards,
May 16, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Nothing shows up in the monitor even the cpu on
Install a new graphics card and plug your monitor into that new video card. Do u get video output? If not, the problem is the system board.If u do, the problem was the graphics card.
Mar 15, 2010 | ASUS P4S533-MX Motherboard
My Samsung monitor 244T blinked several times and went black. A few days later I rebooted my computer and it blinked twice and went black. Now power light doesn't even go on. Help!
1).check your monitor cable and power cable.search google for how to check if you do not know...
2).change your RAM into another slot and check if u have 2 RAM interchange it and check..i prefer this must be the RAM problem..
normally when u insert any new RAM..sometimes it does not matches.. in this way the blinking can be happened...
3).disconnect all the cables of CD drive and DVD drive and any other except harddisk cables...and start the system with harddisk and without connecting the CD and DVD drive..
4).clean your processor cooling fan..search google for cleaning cooling fan..this makes the processor to reduce heat or apply cool paste to processor..
let me know that your computer monitor works fine with the above steps...."rate"
Feb 02, 2010 | Samsung SyncMaster 244T Monitor
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
Computer turns on, but there is no display on monitor.
my goodness.. you have spent a lot in your computer i think.. i dont think changing mother board and installing a new vedio card will solve this problem.
as u have said that u have installed a new card make sure that you are giving the connections of your monitor to the gforce card and not to the mother board again.
if connection for monitor is going for gforce properly your RAM is the problem. as per your configuration its single 512mb ram. i would advice you to go and get another DDR RAM(same 512 prefrably) from any of your friend and put it in you mother board in by removing the normal RAM you had.
this will work for sure i think.
if this is not working dont rate me in-approtiate. i just triend my best. sorry and tahnks.. good luck
Dec 28, 2007 | Computers & Internet
Monitor stuck in black
reboot your computer in safe mode, and then see if it will come up to allow you to change the resolution back. It sounds like you need to check that monitor model to see if it is compatible with this game. you may need a different one. To start in safe mode, on startup, you should see (before Windows starts loading) eithe to press F9 or F11 for startup options, then choose safe mode. Log in, change the res (right click desktop, properties, settings). reboot to normal startup and see if it is ok.
Dec 16, 2007 | HP Pavilion F1703 17" LCD Monitor
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Compaq Presario 5000 PC Desktop Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
