I have Windows XP Professional. My CD's open ok but won't eject unless I restart the computer. How to correct this?
  • amnonka Jan 07, 2009
    I have Windows XP Professional. The CD works ok but will not eject unelss I restart the computer. Apparently there is an upgrade to correctr this. Do you know what it is and how to get it?
  • 837 Answers
You may also want to try a disc cleaner ..
Posted on Jan 07, 2009
  • Jay Glendenning
    Jay Glendenning Jan 07, 2009
    Your problem is not software .. it is your CD drive. If a cleaning doesn't correct it a replacement is necessary
  • 238 Answers
  • Try using Disk Management under Computer Management. Right click on the drive and then select "Eject".
Control Panel >> Administrative Tools >> Computer Management >> Disk Management >> Eject
  • Uninstall the software of your cdrom. Reboot your computer. Reinstall the cdrom driver.
  • Reboot your computer.
    President:
  • 1,314 Answers
I have a pretty good idea that you are using drag-and-drop to burn files to the CD. If so, you probably have an open session that is keeping the drive in an active state. You can right click the application's icon (such as Roxio DirectCD) in your system tray and select "close" or "eject" (don't select "close" unless your disk is full, or you won't be able to add any more files to it). Or you can open My Computer and right click on your CD drive and select "Eject". Either of these options should let you swap out the disk. If not, and you are using Direct CD, check out this web site: http://www.roxio.com/en/support/dcdwin/livingdcd.html
  • 59 Answers
Will it eject in My Computer right click the CD drive and click eject? What type of CD's (software,pics,music)? It sounds like the file is still running.
  • 6,487 Answers
Try to go to Mycomputer and right click your Cd drive and select eject, if it still the wont eject you may need to uninstall and reinstall the software for that cd drive...
    Genius:
  • 1,550 Answers
Do you find small hole in your cd drive . If yes then insert pin inside it to take the cd out . Then you need to open the cd drive and check whether motor is working properly .
    President:
  • 2,110 Answers
Check the power cable to the CD drive..if it is ok..then the motor of the drive needs to be replaced...
I facing a problem to log on my laptop...when i open my computer showing that re install bpl....
Insert your Windows XP CD into the optical bay of your computer.
  • Restart the system and wait for the "Press any key to boot from CD" notification. Press a random key and then press "Enter" to access the XP setup page.
  • Press "F8" to accept the Microsoft Windows XP license agreement once you have reviewed it.
  • Select your current edition of Windows XP from the hard drive using the keyboard's cursors and then press "R" to begin the repair process on the device's Windows installation.
  • ok
  • Sep 07, 2013 | Microsoft Windows XP Professional for PC
    Tip
    Change the volume licensing product key on a Windows XP SP1-Based Computer
    Because of changes in Windows XP Service Pack 1 (SP1), Windows XP-based computers that use a leaked product key that is known to be available to the general public may not be able to install SP1 or automatically obtain updates from the Windows Update Web site. For an easy and quick method of obtaining your own CD Key please read Quickly Retrieve Windows CD Key
    If you have only a few volume licensing product keys to change, you can use the Activation Wizard.
    Warning!
    This document contains instructions for editing the registry. If you make any error while editing the registry, you can potentially cause Windows to fail or be unable to boot, requiring you to reinstall Windows. Edit the registry at your own risk. Always back up the registry before making any changes. If you do not feel comfortable editing the registry, do not attempt these instructions. Instead, seek the help of a trained computer specialist.
    Note: Microsoft recommends that you run System Restore to create a new restore point before you complete the following steps:
    1. Click Start, and then click Run.
    2. In the Open box, type Regedit, and then click OK.
    3. In the left pane, locate and then click the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents
    4. In the right pane, right-click OOBETimer, and then click Modify.
    5. Change at least one digit of this value to deactivate Windows.
    6. Click Start, and then click Run.
    7. In the Open box, type the following command, and then click OK. %systemroot%\system32\oobe\msoobe.exe /a
    8. Click Yes, I want to telephone a customer service representative to activate Windows, and then click Next.
    9. Click Change Product key.
    10. Type the new product key in the New key boxes, and then click Update. If you are returned to the previous window, click Remind me later, and then restart the computer.
    11. Repeat steps 6 and 7 to verify that Windows is activated. You receive the following message:Windows is already activated. Click OK to exit.
    12. Click OK.
    13. Install SP1 for Windows XP.
    If you cannot restart Windows after you install SP1, press F8 when you restart the computer, select Last Known Good Configuration, and then repeat this procedure.
    on Apr 25, 2010 | Microsoft Windows XP Professional for PC
    It doesnt write arabic
    1. Click on the start and go to Settings - Control Panel
    2. Open the Regional and Language Options applet
    3. On the Languages Tab check the "Install the file for complex script and right to left languages" checkbox to select it
    4. Click OK
    5. Insert the Microsoft Windows XP CD when prompted and allow installation to complete
    6. Restart the computer when prompted to do so
    Mar 08, 2011 | Microsoft Windows XP Professional for PC
    I want to change my windows xp to Home edition
    You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
    Oct 27, 2010 | Microsoft Windows XP Professional
    How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
    When you install Microsoft Windows XP, you may receive the following error message:
    [Files Needed]
    The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
    This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
    To resolve this issue, use the appropriate method for your computer.
    Hard disk formatted with FAT or FAT32 file system
    If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
    Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
    Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
    Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
    c:
    copy cd-rom:\win98\smartdrv.exe
    copy cd-rom:\tools\oldmsdos\xcopy*.*
    Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
    c:
    copy cd-rom:\win9x\smartdrv.exe
    extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
    extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
    extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
    Hard disk
    At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
    c:
    copy drive:\windows\smartdrv.*
    copy drive:\windows\xcopy*.*
    Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
    Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
    smartdrv
    xcopy cd-rom:\i386 drive:\i386 /e
    Restart the computer, and then start the Setup program again.
    When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
    Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
    If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
    Method 1
    Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
    322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
    When you receive the error message, press SHIFT+F10 to start a command session.
    Type regedit.exe, and then press ENTER.
    Click HKEY_LOCAL_MACHINE.
    On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
    When you are prompted to specify a name, type Test.
    Locate and then click the following key:
    HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    Delete the UPPERFILTERS and LOWERFILTERS registry keys.
    Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
    Click File, and then click Exit to quit Registry Editor.
    If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
    If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
    Method 2
    If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
    Install Windows in the other partition.
    Start the new installation of Windows, and then start Regedit.exe.
    Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
    Method 3
    If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
    For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
    307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
    Apr 27, 2010 | Microsoft Windows XP Professional With...
    Install arabic language to my computer
    1. Click on the start and go to Settings - Control Panel 2. Open the Regional and Language Options applet 3. On the Languages Tab check the "Install the file for complex script and right to left languages" checkbox to select it 4. Click OK 5. Insert the Microsoft Windows XP CD when prompted and allow installation to complete 6. Restart the computer when prompted to do so
    Jul 10, 2009 | Microsoft Windows XP Professional for PC
    No arabic languag in the windows xp
    Go through following steps.Just make sure you have your windows XP CD.
    1) Click on the start and go to Settings - Control Panel
    2) Open the Regional and Language Options applet
    3) On the Languages Tab check the "Install the file for complex script and right to left languages" checkbox to select it
    4) Click OK
    5) Insert the Microsoft Windows XP CD when prompted and allow installation to complete
    6)Restart the computer when prompted to do so
    Thanks
    Feb 27, 2009 | Microsoft Windows XP Professional for PC
    My operating system not uninstalled
    What is the system doing when you try to change the operating system?
    You should be able to uninstall the SP in ADD/REMOVE Programs.
    Nov 24, 2008 | Microsoft Windows XP Professional
    Microsoft says my os is not an authentic version but it is
    Sometimes Windows asks for you CD as a security measure if your security has been used too many times.
    You could run into some problems with updates unless this is corrected.
    Jun 11, 2008 | Microsoft Windows XP Professional for PC
    How to install Windows XP Professional SP2
    Check this Sol'n..
    1. Boot(start) ur computer.
    2. Press F2 to open up your BIOS Setup
    3. Go to boot menu and set the 1st boot order to CD drive using function key. ex. F5
    4. Change the SATA settings to IDE. Not
    5. Save the new settings using function key before exiting. Ex. F10
    It will restart and surely boot on your XP cd (if inserted)..
    The rest are typical OS procedure.
    From
    #14DeeP
    CCC-OTC Computer Operator
    Mar 09, 2008 | Computers & Internet
    Computers & Internet Logo
    21 people viewed this question
    David Payne
    David Payne
