Question about Frigidaire ATF6000ES Front Load Washer
The washer will not turn on. Leading up to this: the washer would intermittantly go through one cycle then stop. We had to "jiggle the switch" to get it to go to the next cycle. Sometimes the washer would complete the whole wash, rinse, spin on it's own. Now it will not work at all. Switch problem??? Washer Specifics: Frigidaire, Gallery, Front Load, XL Capacity, Heavy Duty, MN: 417.39012890, SN: XC84098149, mfd by White Consolidated Industries, Augusta Ga for Frigidaire Please Help!!! Thank you in advance!!! Beth Hatch
  • 3 more comments
  • buildermch Jan 11, 2009
    Hi Bill,
    Nope, it's a front loading washer. Model # info below:
    Washer Specifics:
    What was happening was that we were more or less "finessing" the knob on the front of the washer to get it to continue the cycle without skipping a rinse or spin.
    Sorry -- I wasn't exactly clear on that, either, was I?
    Thanks for answering.
    Beth
    Bill,
    Thanks for your help. We'll try going the timer route; and thanks a lot for the factory manuals link -- that's really helpful!
    I'll contact you if we need more help.
    Beth
    Thanks Bill.
    Better Safe Than Sorry (or, in this case, Fried...)
    Beth
  • piyataylor Jan 11, 2009
    Our Frididaire front load model # GLTF1040ASO will not operate at all. The timer will move but will not dispense water nor agitate. What should we do other than getting a new one. Please help? Thank you.- Piya
    Guru:
  • 93 Answers
Check your lid switch, sounds like a top load whirlpool or kenmore problem.
Post a model number and I can help you out further.
Thanks,
Bill
Posted on Jan 09, 2009
  • 1 more comment
  • Bill Newberry
    Bill Newberry Jan 11, 2009
    When you say jiggle the switch, you mean the timer knob? Or are you talking about the door switch?
    LOL, I was a little off on the whirlpool top load. But anyway. It happens.
    Let me know what your jiggling.
    Thanks,
    Bill
  • Bill Newberry
    Well, it sounds like a short inside the timer. It's possible to have a dead spot or basically some burnt contracts inside the timer that will cause it to not pass a certain spot. It may have happened once in a while then over time completely stops in that spot everytime.
    I've been on many calls like this one and replacing the timer will get your machine back to normal.
    Here is a link for some repair manuals that may help you out with this. These are the factory manuals for frigidaire appliances
    With this complaint they are going to tell you the same thing that I just told you basically. You can try removing the timer and disassembling it, then cleaning the contacts inside the timer. It is possible that the ends of the contacts have burnt completely off then there is nothing you can do but replace the timer.
    Good Luck,
    If you have anymore questions please ask. I will be more than happy to help you further.
    Bill
  • Bill Newberry
    No problem, Good Luck. (unplug the machine when you work on it)
    I have to say it!!
    Thanks Again,
    Bill
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer has stopped and won't move on to rinse cycle and won't drain. It's done this before but if I jiggled the lid, it would continue. That is no longer working. The washer has finished the wash cycle...
Its the lid switch that is defective..located under the top panel portion of the machine and engages the lid when it shuts as a safety device....unplug and try to locacte it yourself.
Feb 23, 2011 | Estate TAWS800JQ Top Load Washer
Washer is acting erratic. spin cycle works sometimes. stops half way through cycle sometimes. got a new belt. what's next? pump or timer. both are spendy $ thanks. frigidaire FTR630ASO
The control monitors the door lock prior to and during the spin cycle as a safety feature. The washer will not advance to the spin cycle when the door lock is not activated and stops when the lock is deactivated during the spin cycle.
In your case, the door lock is working intermittently causing the washer to spin intermittently. This is probably due to a faulty door lock and switch assembly or poor connection at the control board or at the assembly itself. Replace the door lock and switch assembly if necessary.
Apr 06, 2010 | Washing Machines
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer stops after agitation cycle, tub full of water. Won't drain. Will drain if advance to spin cycle. Top losder
if washer will wash drain and spin when timer is turned manually suspect timer although have known an intermittant problem with lid switch
Sep 22, 2008 | Whirlpool Washing Machines
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Runs full wash cycle, but there it is still full of water and suds
Amy, there was a service flash for the lid switch on this model. The contacts inside the switch were sporatic which caused; stopping in mid cycle, wet clothes and no drain. You would have to put it in spin and have someone jiggle the wires to the lid switch to verify that this is the problem and not a timer problem. I really think it's a lid switch problem. Your part number for the new, non adjustable switch is 12001908.
Jan 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Stops midcycle, restarts when you lean on it
If the problem lies with the contacts, then the knob is not the direct problem, it would be the selector switch behind the knob. Although I don't understand how leaning on the to makes the machine work. Are you sure it is not the switch that indicates when the lid is closed? Either way, Yes!! you can simply just change the switch over.
Jul 27, 2007 | KitchenAid KAWS850L Top Load Washer
Washer not turning on
Check the lid switch...sometimes the get loose on break and will could cause this type of problem
Mar 11, 2007 | Whirlpool LSB6300PW Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
332 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
