Question about Sony STR-DE445 Receiver
Speakers pop and rear speakers cut out of surround sound
I have the Sony STR-DE445 surround sound receiver. All works fine for about 3 Minutes and then there is a very loud pop from the speakers and the two rear effect speakers cut off. If I shut it off and try again it does the same thing each time. The remaining speakers work fine. Any ideas ?
  • Anonymous Jan 25, 2009
    It's time to get a new one Mine just stared to do this last month it would cost me 400 bucks to get it fixed so I went on line and look at getting a new one I now have a STR_DG820 and I love it
  • carp568 Apr 27, 2009
    hey i have the same receiver (str-de445) and it turns on, but right before its about to produce sound, it goes on protect mode. is it because the fuse is too big? the fuse is a 5A 125V, and the original fuse is supposed to be a 2.5A 125V
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
  • Jager Mitchell
    Jager Mitchell Nov 14, 2014
    Danke sch?n! The only solution to this question on this site that worked. Luckily I took 4 years of German ;)
Have sony STR DE445,sound cuts off ,will come back when I tap on cabinet,seems to work ok with headphones.
remove all the speakers clean wires and connectors put a drop of oil in headphone socket and try again this is due to rusting and dust
Jun 04, 2010 | Audio Players & Recorders
I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Jan 01, 2010 | Sony STR-DE845 Receiver
NO SOUND FROM REAR OR CENTER SPEAKERS.JUST THE FRONTS AND SUB WOOFER WORK.
have you checked the wiring of the speaker some time the can cut internally so to check use a small wire and connect just like the one which is in the manual this Can solve the problem
Nov 19, 2009 | Sony STR-DE445 Receiver
DE 445 flashes "protect" and sound goes off when loud noises play on DVD
Check your speaker connections at the back of the receiver and at the speakers. You have a short. If you don't see anything obvious, disconnect your speakers at the receiver and play a dvd and turn up the volume. If it stays on, you have a wire or a speaker problem. If it cuts out , you have a DSP chip problem. Reconnect speakers one by one and test each speaker until it cuts off or you have fixed the problem. If you still have issues, post a comment and I can help you some more.
Aug 07, 2009 | Sony STR-DE445 Receiver
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
Rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Mar 02, 2008 | Sony STR-DE625
Sony STR-DE445 Receiver Logo
1,635 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
