Question about Roper RES7646KQ Electric Dryer
Heating elements energize then go off after a minute or so
Maytag, every thing else seems fine
  • Roper Master
  • 1,250 Answers
This sounds like an overheating problem.
There is usually a limit device near the elements.
There is also a limit located in the exhaust. If the exhaust air becomes restricted, it takes the heater out of the circuit so it does not burn out or worse.
I would look at this as a possible answer.
Good Luck and hope this helps.
Posted on Mar 13, 2009
Why is my maytag electric dryer not heating, I checked the high limit fuse for continuity, it's fine, I pulled the heating element and saw no breaks it also checked good on continuity
Several things can cause this. Improper voltage, inadequate venting, thermostats, fuses, burnt wiring, heating element, timer, or motor. Someone will have to troubleshoot all that v
Nov 18, 2017 | Maytag Dryers
Maytag dishwasher. Dishes on top rack are not being cleaned. Also, top part of the door remains dirty. It seems like no water is reaching top rack. Tried checking and cleaning out drain. Dishwasher...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 28, 2011 | Maytag Dishwasher
Maytag 24 in. MDB3700 Built-in Dishwasher seems to fill with water, but the arms are not working, no washing going on.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 18, 2011 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag Neptune Dryer runs for about 10 minutes and then stops. If we hit the start button it will run for another 10 minutes. It heats up fine while it is running. When this started we smelled something...
Check for lint buildup on the "Hi Limit Themostat" located above the heating element. There is a thermostat kit that you can get and replace all three at once. This will make sure your dryer runs safe and up to its required operational limits. The lint buildup may cause the thermostats to get out of the tolerance. Here is a link to the thermostat kit.
The FixYa Team
Dec 26, 2010 | Maytag PYE2300AY Electric Dryer
I have a Maytag MDB4709AWS dishwasher that's not doing a good job cleaning dishes. Even on heavy duty cycle I still have small particles stuck inside my cups and on top also. I wanted to remove the inside...
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Dec 09, 2010 | Maytag MDB7100AWB Dishwasher
Maytag eq plus, not cleaning properly, seems the
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Jan 01, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag Dryer not heating up
you need to be getting at least 220v to the terminal block, if you don't check recepticle and the breaker
Jun 01, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
MAYTAG PYE2300AYW ELECTRIC DRYER - HEATER SHUTS OFF PREMATURELY
First off, how are you looking to check this situation. Either way, it would be normal for this to happen. When you are looking at the elements heating, you more than likely have the door open to see them. The heater will do what they call "short cycling" because the airflow has outside source air getting into the heat stream. The door and lid almost always has to be shut for this system to work correctly. You can sometimes crack the top just enough to see the element heat. Usually, if the element is coming on at all, then the system should be fine. If you have a dryer thats not drying your clothes completely, its more than likely you have a ventilation issue (i.e vent tube restriction, grass growing in the end of the vent, etc). Also remember these Maytags have two thermostats on them most of the time. One directly over the top of the element, and one in the fan housing at the front of the unit. Try those, if there isnt a change, write me back and will look from there. Good Luck!!!!
Feb 01, 2008 | Maytag PYE2300AY Electric Dryer
Roper RES7646KQ Electric Dryer Logo
48 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
