Question about RCA F27442 27" TV
RCA 27665 27"
Turn on relay is operating and tube starts to charge, but then the relay turns off and on and off again by itself. This all takes about 10 seconds. Picture and sound do not come on.
  • i1nt2fixit Mar 05, 2009
    when I plug my tv in it makes a chirping sound????
    Problem Solver:
  • 11 Answers
Check c14110 and c14122 off main b+
Posted on Jan 08, 2008
Just got it new.....screen won't go past rca logo
Why wont my rca tablet load past the RCA logo screen? - I ...
www.askmefast.com > Consumer Electronics > TVs > Tablet
Laptops & Notebooks .... My rca tablet wont go past the first logo screen and i have factory reset it and ... Some how the factor reset button on the back of my rca 7in tabletgot pushed and ..... Rca tablet will not play games it just goes back to home screen ....My rca 7 tablet is stuck at the main screen and it won t go any further.
my rca tablet won't turn on I tried charging but it's not working ...
www.tomsguide.com/forum/id.../rca-tablet-turn-charging-working.html
Dec 15, 2015 - 12 posts - ‎10 authors
My rca tablet isn't working I tried charging it but it's still not turning on ... Hold them both in this position until you get a menu on the screen. .... I've repeated this attempt to turnit on it just flashes on the battery logo with an exclamation point ... SolvedMy Asuslaptop model Q551L won't turn on or charge what ... Tablet keeps turning off - Battery
Nov 16, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
RCA tablet no power-up - Power Up
Mar 30, 2015
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Dec 25, 2015 | Computers & Internet
Why is it erratic starting and only displays half of the picture?
problems with crts are difficult to diagnose. this could be due to a failing tube or faulty electron gun...It is probably best to call in a technician to take a look.
Jun 26, 2015 | RCA Televison & Video
Water won't turn off
Sounds like the pressure switch is not working.two reasons for this the tube that operates the switch to turn off the water sits outside the drum and is normally full of air.as the drum begins to fill it increases the air pressure in the tube to the point where it trips the switch to turn off the water input.if the tube fills with water it will not operate the turn off part of the operation.you either check the tube for water by open inning the top and disconnecting the rubber hose from the drum and empty out any water.this should make it operational again.if not then it is probably the switch itself.easily replaced by parts obtain through eBay for your model machine.not difficult to do, tutorials on YouTube are available on this topic.
Mar 08, 2014 | LG WM1814CW Front Load Washer
My TV does not turn on. Well, turns on but I can't see nothing because the screen does not turn on , and the TV turns on and turns itself off. Help!
Many different problems occur in these. Power supply, convergence, picture tube. Take it to a shop. Power supply failure is safety issue.
Jan 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't start...nothing happens when i turn the key. My fan to cool down the radiator won't stop running now i get nothing. what could be the problem
Likely the relay that operates the fan motor has burned itself in the on position. Relay is usually found behind and below r/f headlight. For now, first thing to do is unplug the fan and charge up the battery using a battery charger. then replace the relay and plug the fan back in .
Jul 01, 2010 | 2002 Jeep Grand Cherokee
My rca player won't turn on. it looks like it is
my rca player won't turn on. it looks like it is going to [screen ilghts up] but then it goes black again. the battery is fully charged
Apr 30, 2010 | RCA M4204 MP3 Player
Why does my RCA model# 27V412T turn on and off by itself? It's does not stay on long enough for me to reprogram the remote.
Hi There,
Sounds like your Startup Relay is intermittent. Contacts are closing (tv on) then dropping out (tv off). Worn or burned contacts do not make a good connection when they close and start to burn and overheat causing the contacts to open. When they cool down they may make contact again for a very short period. You need to replace the Start up relay. I hope this helps and thank you for using FixYa!
Mar 29, 2009 | RCA Televison & Video
RCA P52937SG Will not turn on, only makes clicking sound.
I had the same problem with mine. There are two voltage capacitors in there. A low and high. The hig voltage is bad. I had to have mine in the shop. Cost about $400
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
Rca p61950 turn on and off by itself??????
Sounds like the front panel buttons are locking up the micro,unplug the unit and remove the back cover,just below were you removed the top screws you can look and see the top of the picture tubes,in fron of the middle tube is a small board,unplug the top left cable and this should restore the unit till you get the set serviced,this will not harm the set,the front buttons just wont work
Dec 01, 2007 | RCA P61960 61" Rear Projection Television
RCA F20539DG
YOU might have a bad relay or a bad solder connection in the relay control circuit. Sounds like a bad solder joint. Stargazer
Feb 27, 2007 | RCA F20645 TV
RCA F27442 27" TV Logo
96 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
