Home | Asko | W6661 Front Load Washer | Asko Quattro 6661 wat...
Asko W6661 Front Load Washer
Problem for Asko W6661 Front Load Washer
Asko Quattro 6661 water inlet fault
By Billy Surfac on Jan 07, 2009
The machine will stop working about 30 minutes into a cycle, I think during the rinse cycle, and then it comes up with a water inlet fault, I can run a rinse cycle seperately and it will do it.
Same Problem
Jan 12, 2009
-   Same symptoms and go around. Replaced top control board due to visible heat damage and still water inlet problem. Could it be the bottom board or is it possible the water level sensor or something could be errant. Water is not a problem, fills well. During rinse is when we have problems.-   baker19
Solution #1
posted on Mar 14, 2009
Not Rated)
CraigNewman
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Was this helpful?
Yes
No
Popular Solutions for Asko W6661 Front Load Washer
Questions and Unsolved Problems for Asko W6661 Front Load Washer
Do you recommend Asko W6661 Front Load Washer?
Answer
Answer
We have the Asko W6661 front load washer. we are trying to replace the bearings. how do we do this?... (More)
Answer
My asko w6661 washer will fill with water but now will not start agitating. It is about 8 years old... (More)
Answer
The panel is faulty - all pixels of the display light up and the machine does not react to any... (More)
Answer
My Asko W6661 washing machine water inlet fault would come on so I check the water inlet line and... (More)
Answer
I own a ASKO W6661 front load washer and the door will not lock shut. I tried force and pressing... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Asko W6661 Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14051
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
