Question about Canopus ADVC-110 (77010150100) Video Capture
Problem in Canopus ADVC-110
I have strange problem - When i connect my ADVC 110 device to my computer it doen't working but when i connect it to my friend computer, it works i think the problem is with my windows or something with my bios Is somebody knows?
  • Anonymous Mar 17, 2014
    Canopus advc 1000
    Guru:
  • 104 Answers
Maybe different OS? If your friend have XP and you have different operation system?
Posted on May 28, 2007
SOURCE:
My Canopus ADVC-110 has both input light on and I
The problem got no free response so I ordered a new unit.
Jan 02, 2010 | Canopus ADVC-110 (77010150100) Video...
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
No analog signals thru ADVC100
Canopus customer support just wrote me back with the bad news: "If all 3 lights are on, then the unit has failed. We no longer
manufacture or repair ADVC 100's (they are almost 7 years old now). You
would need to purchase the newer ADVC 110 as a replacement."
Dec 12, 2008 | Canopus ADVC100 (77610072100) Video...
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
Can the Canopus ADVC-110 be reset
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email hayden@hayprofilms.com just to let me know good luck bye.
May 07, 2008 | Canopus ADVC-110 A/D Converter...
IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
ADVC-110 not working for me
iMovie or Final Cut Pro should work.
Sep 18, 2007 | Canopus ADVC-110 A/D Converter...
Canopus ADVC-110 (77010150100) Video Capture Logo
291 people viewed this question
Top Canopus Televison & Video Experts
Archie Ferrarini
Archie Ferrarini
Alun Cox
Troy Staley
Troy Staley
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
