Dualing Remote Controls for Dish Network
Evidently someone in our neighborhood has the same frequency remote control we have for our 2nd television (designated T.V. 2).
We constantly battle to control what we're watching - neighbors apparently don't have the same tastes we have. Is there a way to shield our receiver from unwanted channel-surfing?
5 Suggested Answers
justuscc
  • 360 Answers
SOURCE: REMOTE CONTROL
remove the batterys to reset memory. store your oyher codes in it before you do this........
Posted on Oct 03, 2008
  • 56 Answers
SOURCE: bought a dish identical remote to Bell Expressvu.
You may need to program to your equipment, go to dishnetwork.com/tech and that will show you how to address your remote.
Posted on Nov 12, 2009
  • 432 Answers
SOURCE: i bought a rca (RCRP05B universal remote) to
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesInfo.do?findManual=RCRP05B
Try this link to see if you ban find your code.Hope this helps.
Posted on Mar 14, 2010
  • 37 Answers
SOURCE: dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Posted on Jul 06, 2010
CheriT Dish
  • 146 Answers
SOURCE: How do I program an Echostar 5.4 IR to control a
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post recently and wanted to see if I could help. The best codes for the 5.4 IR remote are 500, 578, 514 and 758. I will also list here for you the instructions for addressing your DISH remote to your Sony TV. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to email directly at Cheri.Torres@Dishnetwork.com. Thanks and have a great day!
Instructions for addressing remote to TV.
  1. Turn the Television On
  2. Press and Hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound (#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Posted on Feb 24, 2011
I have a nuwire for my remote controls for mulitiple items and i can't get it to work on my dish network system
romaneastwoo,
What type receiver is your TV connected to? Do you know your remote model number - located on back of the remote at the top (ex. 2 digit number 5.3 ir). The majority of our TV 1 remotes work in IR mode. If this universal remote uses UHF frequency, it will not work for the IR frequency. Please let me know your receiver and remote types and I will see if there is anything we can do for this remote.
Ray Calo
DISH Network - Executive Offices
Jan 11, 2011 | DISH Network IR Remote Control
Have a new Vizio LCD tv , My Dish remote will not work only manual at the the box what wrong
Hello, Daniel Busa with Dish Network customer service. on those lcd tv's they will interfere with your remote. You have two solutions, you can turn off the back light feature in the tv menu, or you can set the remote to a uhf frequency which will probably require a new remote.
Dec 09, 2010 | DISH Network IR Remote Control
The dish network 2nd remote isn't working I put in a new code because we bought a new tv for that room. Now, i can use the dish remote to do everything without the tv remote but NOTHING works on dish...
Hello, you may have gotten this resolved already, but if not, here are some simple steps to get this resolved. Follow these simple steps on our website, and you will be good to go!!! For this also, you will want to be at TV1, in the system info screen. Menu twice with TV1 remote. :)
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
Nov 28, 2010 | DISH Network IR Remote Control
How do I program a 2nd remote to my sattilite
mandysnw,
Here is a website on how to program the remote.
http://www.dishnetwork.com/SupportSection/remote-setup. Not all remotes are compatible with all receivers. Plus if the receiver controls 2 TVs, there is a colored tab on the bottom of the remote that controls the remote functions. I hope this helps.
Ray Calo
DISH Network
Aug 16, 2010 | Universal Remote Control DISH Network...
Replaced a Dish VIP722 with the new VIP722k,--got new remotes, also have a Bellvu 3100 on same primary TV. Used to be able to use one remote to control either recever boxes. How to I add the 3100 to the...
d1032d_junk3
If you are using the remote to operate an IR frequency, you can program that component to the VCR or AUX button on the new remote. I have provided the instructions on how to program the remote. I hope this helps.
Address To 2nd IR Receiver Using AUX Mode
  • Remote: 3.4, 4.4, 5.3, 5.4, 6.3, 6.4, 20.0, and 21.0
    1. Go to 2nd IR receiver
    2. Go to System Info Screen
    3. Hold down the AUX button until all mode lights light up.
    4. Press 3 then enter a number between 1 and 15 using the numeric keypad on the remote.
    5. Press the pound (#) button
    6. Once the AUX button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Jun 13, 2010 | DISH Network IR Remote Control
Dish network control not working on 2nd. tv
Jun 02, 2010 | DISH Network IR Remote Control
I need to set 2nd tv remote how do i do that?
Hi aajwknightmy name is Mike Houston of DISH Network after reading your post there are somethings that can be done to fix the remote. The first thing you will want to dois take the TV2 remote to TV1 and on the TV1 remote press the MENU button twotimes and it will take you to the System Info screen. At the bottom of thescreen you will see the Secondary Remote Address and a number in the white boxto the right, and with the TV2 remote press and release the SAT button andpress the record button one time.
Jan 06, 2010 | DISH Network IR Remote Control
Bought a dish identical remote to Bell Expressvu.
Nov 06, 2009 | DISH Network IR Remote Control
Dish Network not working all... lights up but nothing else!
call dish network. they have all the information you could possably need.
their phone number is inside your recivers manual
Aug 19, 2009 | Universal Remote Control Dish Network...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
