Question about Oreck XL21 Bagged Upright Vacuum
Where do the cotter pins go on an Oreck upright vacuum? Thanks. Sally from Lake County, Ohio
I called the Oreck Company in the late night. They are in service 24/7. The employee instructed me on where the cotter pins are attached. Glad to help someone.
Posted on Jan 07, 2009
How do i reset my oreck xl edge upright vacuum
check the Oreck web site or utube for solution. the manual maybe available on Oreck web site.
Dec 16, 2014 | Oreck XL Edge Upright Vacuum
Install instructions orick power cord upright
You can find the assembly and wiring diagrams on this site to help you. Please check the correct model number as you have not provided this.
Oreck Upright Vacuum Parts
Aug 30, 2014 | Oreck Orek Upright Vacuum Cleaner -...
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
I NEED TO CLEAN UPRIGHT HANDLE TUBE IT IS CLOGGED
Its a simple operation but it will take some time.  On the back of the Oreck just up from the motor you'll come to the first rubber ring which hides the push/pin locks of the main spine. There are two or three on the Oreck depending on the XL model - slide them down to reveal the pin locks and push them in wards to unlock the main spindle pipe. At the same time ensure that the bag clip at the bottom has been unclipped and the cord is also free, taken off the hooks at the back. The main pipe/spine at the back is the main dust channel so this is the first place to check for a clog and then upwards towards the handle/dust channel feeder - there is usually a small screw on the square part at the bottom which loosens the main handle from the body of the spine.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck xl vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19805&thid=719784
Oreck XL vac
Posted by ddevol on Jun 29, 2008
Air flow tube is plugged. I can't get it apart to clean out. It says to press the 2 pins at the base but they don't move when I try to press them, even using pliers.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The tube going into the motor section is to push the pin and then twisted, the lower part get a dust and dirt build up and sometimes hard to remove, give it a shot of WD-40 @ the top and bottom of the fill tube and then repeat the pus in the tab and twist and it should come loose. There are also in the bigger cities the Oreck stores that you can also bring it to as well. If you have further problems or you do not have the strength to do this, bring it to a local vacuum cleaner dealer in your area and it is only a 5 or 10 minute job to remove the tube and to unclog the vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Oreck XL21 Bagged Upright Vacuum
My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Jun 07, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL21 Bagged Upright Vacuum Logo
112 people viewed this question
Top Oreck Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
