Question about Microsoft Xbox 360 Console
Xbox 360 freezes while loading
My Xbox 360 console worked fine for the first few days I had it. However, after using it without a problem for several games, I found that the game Madden 2009 was freezing during the loading screen almost every time I tried to use it. While loading, music plays and it give you facts about teams. What should happen next is that the music should die down, the screen should jolt, and then it should take you to where you're going. But with mine, although the music dies down and the screen jolts, it then just continues showing the loading screen. The facts will continue so I know that it is not broken and the loading bar says that it is still loading. This problem didn't happen with other games like Halo 3. Then I noticed that the same problem did happen for NHL 09. This makes me think that the problem is only happening for EA sports games. If I turn off my Xbox and try again, it will load properly on average once out of 2 or 3 times.
  • 1 more comment
  • ginge3000 Jan 07, 2009
    i have the same problem with beijing olympics most times that it tries to load, the loading circle starts to spin and then it stops and completely stops loading but that is a SEGA game so it isnt just EA games, but hopefully someone will find a solution to this problem.
  • Anonymous Jan 17, 2009
    same thing happens to me with madden 09 and half life 2 but then i installed half life to the hard drive and it works fine.
  • datagogo Jan 21, 2009
    For anyone who is interested, my local game store told me that the intercoolers were not worth it, because they weren't that effective and by drawing air into the console it got damaged by dust and other particles. They suggested placing both the console and the power brick in a spot where there would be adequate air flow underneath and on all sides--not on the floor, a shelf, or on top of a TV. (You can buy something that does the trick for $30 at any store that sells laptops.) This seems to have fixed my problem. The store also told me that for xBox 360's, Microsoft will refurbish or replace units that aren't working for three years, and you don't even have to have your receipt, just the serial number (although they'll argue with you and you have to insist). Good luck!
Try Installing it to your hard drive, it stopped the freezing for me but just took up some space.
Posted on Jan 17, 2009
2 Suggested Answers
  • 8 Answers
SOURCE: Ea Games NHL 09 and NHL 10 won't play
I would recommend going back to the shop you got the game from and asking for a new copy, it seems more likely to be a disc problem than a console one, and just check that it is the correct format for your region.
Posted on Apr 08, 2010
Xbox 360 loading fault with dotted screen, checkered. freezes on loading screen even. sometimes it can appear there are several lines down the screen aswell so it may be 2 faults.
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Jan 12, 2010 | Microsoft Xbox 360 Console
Xbox freezes when trying to load saved game
hold the disc by the edges without touching the surface.
clean the disc with soft cloth from center outwards.
do not use any solvent,
examine the disc for any visible damage.
verify wether the xbox clock is set correctly.
Mar 05, 2009 | Microsoft Xbox 360 Console
My sound works but my video doesnt
your xbox is gunna get the rrod soon (red rings of death) my xbox had this prodlem few days later rrod happend technically the only thing you can do is well w8 for it to get the rrod and send it in if you got your warranty still if no warrenty is on it well have fun paying 140$ to get this problem fixed or go on youtube after it rrods and look up the xclamp repairs for xbox 360 i have used it on several xbox 360s it seems to work fine after words
Jan 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 freezes and Dotted Lines Appear
hi
my xbox has the same problem as above, also we have three red lights on console is there a solution?
xbox live :leighjay
Nov 26, 2008 | Microsoft Xbox 360 Console
Xbox 360 taking longer to load up
Concidering that your warranty was renewed when your console went in for service, I would call microsoft and tell them of the error. Also, when they re-set your console, they made it so that you have to manually sign in.
Apr 08, 2008 | Microsoft Xbox 360 Console
Freezing up
Try removing your harddrive to see it that's what is causing the problems. Games should play fine without harddrive, but no save, of course. It it works without HD you may need to replace yours.
Dec 20, 2007 | Microsoft Xbox 360 Console
Sound quits after game loads.
are you using original xbox games or 360 games
Dec 16, 2007 | Microsoft Xbox 360 Console
Xbox 360 dvd player
try this link sir! http://blogs.chron.com/techblog/archives/2005/12/microsofts_xbox.html
Mar 20, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,454 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
