Question about SharpVision XV-Z9000U Multimedia Projector
Projector periodically displays blank screen
I just replaced the lamp on my XV Z9000U projector. The lamp only has 150 hours used. When I turn on the projector, the picture displays but doesn't appear clear (a sort of flashing with lines across the screen seems to appear). After watching a movie for a few minutes or sometimes longer, the picture on the screen goes blank as if the projector is not even on. However, the blue light on the projector is still solid blue and the projection light on the projector still shows a bright light as well. After a minute or so, the picture reappears and this issue may or may not happen again. This has happened several times in the past month or so.
Any suggestions or help would be appreciated.
  • Sharp Master
  • 19,396 Answers
If the problem happens randomly, and the unit recovers after the raster disappears, then it is likely a contact problem.
It sounds like it is either a bad lamp contact, a bad cable contact (screeen usually blue , not blank), or a bad solder joint (loss contact on board) on one of the internal board.
All you can do is removing carefully the lamp and putting it back in place, following instructions on manual.
See the manual here: XV-Z9000U Operation Manual
Posted on Jan 09, 2009
  • 716 Answers
Have You Tried Cleaning The Filter?
Posted on Jan 07, 2009
    Genius:
  • 1,550 Answers
This tends to be a ballast problem in your projector .
How old is your unit ?
    President:
  • 2,110 Answers
I had the same problem after I replaced my lamp. You need to hold down the:
On
Enter
Down Arrow
Right Arrow
simultaneously - this resets the lamp counter. After I did that my projector fired right back up.
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
I am unable to reset the timer after replace projector lamp- there are no screen. How to reset the timer?
Have a nice day!
Jerry
Lampdeng Limited
I have a Sharp xv-z9000u projector. I recently replaced the lamp; however, I cannot turn the projector on. how do I reset the lamp timer?
While pressing down arrow, right arrow and ENTER on the projector, press POWER ON on the projector.
Jun 04, 2011 | SharpVision XV-Z9000U Multimedia Projector
I have a sharp projector xv-z9000u. I replaced the lamp and now I cannot turn on the projector. What should I do?
there may be a reset button some were on the projector you have to look real good, i do know that some projectors when you replace the light bulb you have to push the reset button than it should turn on.
My sharpvison z9000u is not powering up bulb was used less than 1000 hours
Hi There Sounds like a lamp has died. The technical lamp hour spec life is only a manufacturers "up to xxx hours" and not what you will achieve in actual life.
If you want we are able to supply lamps as we ship internationally, @ $US335 for a SharpVision Z9000u Regards Kevin Andreassend http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jun 27, 2009 | SharpVision XV-Z9000U Multimedia Projector
Rolling picture
Have you tested the source machine on another TV or projector. The picture might be rolling before it gets to the projector so you need to verify whether it is the source machine or the content then you might be able to determine if it is the actual projector. Sounds like the vertical sync has got lost somewhere.
Hope that helps. Also we can supply lamps for this model if you ever need.
Re your Sharp XV 9000S We are able to supply replacement lamp+housing delivered (excluding local your local taxes) for $US342 as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jul 13, 2008 | SharpVision XV-Z9000U Multimedia Projector
Lamp life over 2000. can't turn on again after replaced
sharp xv z9000u bulb reset
Hold down Enter + down arrow + right arrow and then power on.
Mar 13, 2008 | SharpVision XV-Z9000U Multimedia Projector
Won't power up
On
Enter
Down Arrow
Right Arrow
Nov 22, 2007 | SharpVision XV-Z9000U Multimedia Projector
SharpVision XV-Z9000U Multimedia Projector Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
