Question about Air Hogs Glow In Dark Havoc Stinger Rc Helicopter
My helicopter spins to the left
As soon as i take off it keeps spinning to the left
  • Anonymous Mar 13, 2009
    mystinger wont stop moving
  • 30 Answers
Theres trim on the remote just hit the r until it stops spinning to the left and it it spins the right then hit the l
Posted on Jan 07, 2009
2 Suggested Answers
SOURCE: Spins like crazy
en la parte de abajo del control del lado derecho en la palanca derecha exactamente tiene dos botones uno (l) y otro (r) la (l) es para cuando el heli comiensa a dar bueltas como las manesillas del reloj y la (r) es para lo contrario otro problema que puede ser seria que las palas estan apretadas y tienen que estar flojas con un pequeño desarmador de cruz las puedes aflojar y el ultimo problema que podria ser seria que un motor ya esta mal espero te alla servido estas soluciones.
Posted on Mar 08, 2009
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
How to find my potentiometer
It is on the hand controller the two buttons on top of the hand grips keep pressing the button until it stops spinning use whichever button left or right depending on the direction of the spin.
Kind regards, Julian
rccontrolfreak.co.uk
Jan 05, 2013 | SYMA Toys industrial SYMA S009 Micro...
World Tech Saturn-X - spins, rudder trim doesn't help
I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at thedew312@gmail.com if you need more help finding where the wires connect
Dec 28, 2012 | Worldtech Devices World Tech 85618 2CH...
The helicopter keeps spinning out of control
sort the trimmer out its what makes the tog spin out of control while in flight
Dec 25, 2010 | The Toy Workshop Helicopter
Ive a s006 alloy shark remote controlled helicopter and i need to adjust it so it stops spining around but instructions arent clear
have you tried using the trim buttons?,after take off when its around 2ft in the air if the tail spins to the right tap the left trim button a few times and if its spinning left tap the right button a few times and this should stop it spinning it works ok on my one
Apr 28, 2010 | Head Cover For Syma Alloy Shark Rc...
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Helicopter spins left and rear rotor does not spin at all
Yes your motherboard shorted out. You need to get a new board or replace the heli.
Jan 10, 2009 | Sky I Blade Mini IR Helicopter W/ Remote...
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Air Hogs Glow In Dark Havoc Stinger Rc  Helicopter Logo
1,700 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
magna buff
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
