Question about Packard Bell Easy One Silver 2101 Notebook
No bootable cd in AT API CD-ROM - Packard Bell E2315
I unplugged a MP3 player by mistake and now the above message is on my PC. It says PXE-E61 Failure, check cable, although there is no cable in laptop now. Then the screen changes and a blue screen appears and it says Boot Device and a list of items ... hard disk drive, CD-Rom/DvD, Floppy Disk Drive, and Lan Boot .. if anyone can help i would be very very grateul.
    Genius:
  • 2,985 Answers
Shut the machine down. Start her up As soon a POST comes up[the black and white screen] start holding down F8 You will get a screen come up with varios options. use uodown arros to Start on last known.. that worked Press return.
Posted on May 28, 2007
NO BOOTABLE DEVICE FOUND,
You probably have a mbr virus.
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Aug 18, 2012 | Intel Computers & Internet
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
My packard bell laptop requires a boot up cd-rom
put the bootable xp cd in your cd rom then turn it on. it will boot up automatically if the cd will be bootable and your boot sequence is correct.
Nov 19, 2008 | Computers & Internet
Aspire 5100 how do i run recovery cd's. notebook won't boot up
hi LWeller1l what you computer is trying to do is boot from a network and it's not picking one up so it gives you an error message, to check if it's just this....... go into your bios and check the boot order it should have ......cd/rom or dvd/rom drive as first boot option then the .........hd meaning harddisk then the pxe boot, if they in this in this order and the pxe option is not above the harddisk in the order you may have harddisk problem. when the computer boots it uses this order to start, so in this order it checks the cd/rom or dvd/rom for a bootable disk, if none is in there it then tries to boot off the harddisk, if this fails then look to the pxe boot option which is network boot option off a server,........another thing is you if you don't have server you can disable the pxe boot option completly in here........so if they are in this order in the bios then you may have to re-install the operating system or the disk may be corrupted or failed.
Oct 08, 2008 | Acer Aspire 5100 Notebook
Acer aspire 3515 reboot
Hopefully, though, there's just some craziness going on with the Boot
....suggests that the error messages you are seeing are from a failed
attempt to boot from a network source.
Check the boot order in your BIOS to insure that the hard drive is
fairly high in the list. Generally, I have it something like this:
(1) Floppy Drive
(2) CD-ROM
(3) Hard Drive
If you do this, will it boot from the hard drive?
Will it boot from a bootable CD?
Oct 02, 2008 | Computers & Internet
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Oct 10, 2006 | Compaq Evo Notebook N200 Notebook
Packard Bell Easy One Silver 2101 Notebook Logo
356 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
