Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
LIftmaster light flickers but won't open garage door
Photo eye is aligned and isn't blocked, but it will not turn on the light when you interrupt the beam.
The wall switch causes a short hum, the light flickers, but the motor dosen't engage.
Liftmaster Security+ 1265LM (12 yrs old)
  • 4 more comments
  • dbldady Jan 07, 2009
    Also there is an l.e.d. light flickering next to a red push button near the limit controls. Five flashes, pause five flashes, pause (I think)
    It might be the remote code settingsbut I never noticed it before.
  • dbldady Jan 12, 2009
    I checked all the wiring connections at the photo sensors and at the logic board. All seem ok, most wire is behind drywall. I have some cat6 I'll try to make a temporary junper with but re-wiring the sesnsors seems difficult. There are moulded plugs into a socket on each side.
    The logic board might be bad anyway.
    What does five flashes mean from the led light next to the red code program button?
    Thanks
    check your wire connections at the opener one of the little wires probably broke
    Thanks
    Thanks
    Thanks
  • Anonymous Feb 02, 2009
    led flashes in back of opener.
    Problem Solver:
  • 8 Answers
Check your wire connections at the opener one of the little wires probably broke
Posted on Jan 10, 2009
  • phil3heth Dec 08, 2010
    I had the same problem. 5 flashes means the motor overheated or the trolley is stuck against the limit screw (the problem in my case). The solution was to create a little slack in the chain by loosening a nut on the trolley carrier and then lowering the door after resetting the unit by unplugging and replugging the power cord. I turned the height adjustment screw so that the door doesn't raise quite as much, so it stops several inches from the limit screw that's mounted to the rail close to the motor unit.
Door wont close
Roger, does lights blink when attempting to close door?? If so it is the photo sensing eyes. Be sure they are not blocked and properly lined.
If all is ok, replace the photo sensors. Hope this helps
Oct 05, 2012 | liftmaster Garage Door 1/2 Hp
I have Liftmaster lifts on both of my two car garage doors. One works just fine but the other one only works when you press the wall button and hold it down until the door is done moving. Otherwise it...
One of your sensors is moving and you need to find out why and correct it. The light flickers when the sensor is on the edge of the beam sent by the other sensor. Think of it as a flashlight.
Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage doesn't come down
The color of your door sensors is normal. Make sure they are pointed at one another and that one of the lights isn't flickering. If the main light is not flashing when the door starts to come down you may need to increase the down force just a tad. It is an adjustment on the rear of the motor unit.
Mar 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Oct 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Photo eyes inop, opener still operates
if eyes came with opener, that is good. clean off lens. are both eyes leds lit. try aligning again. New eyes avail for $30 if you want to try.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sensor light
I assume you have a Craftsman or Liftmaster operator and you are talking about the photo eyes (sensors). If this is true thanone light will remain on if there is power to it and the other will go out when the photo eye beam is blocked or are not lined up.
Thank you for your your question bry4man. I look forward to answering any more of your questions.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programing limits on a Grifco MK3 Garage door Operator
It has the "Protector System" (safety sensors). chec the sensor indicator light on the receivinng eye the green light had a slight flicker.cleaned both the sending eye and receiving eye lens of dust and cob webs, then realigned the receiving sensor for a steady green indicator light. then check the door function it now works fine.over time, temperature, and viberation the sensors become dirty and get out of alignment, as no one had tampered with the sensor alignment prior to this. Hope this works for you.
Nov 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener /
door will not go down unless you hold down the inside botton.
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,663 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
