Question about U-Line 15WC Wine Cooler
ISO cooling fan
No. 05/065815
SA12645
Date Code: C-511-CC
120V
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding your product was manufactured in Asia by Shenzhen Xinhuahui Industrial Co., Ltd., and therefore purchase of replacement parts may prove to be a bit challenging. With this in mind, might I suggest that if you are intending to replace the blower/fan, remove the original and use it as a "as/sample" when purchasing replacement. You might have better chances on "over the counter" purchase (to visually compare the fan) rather an online purchase. Likewise needed are the electrical specs such as operating voltage and Hz/cps if so indicated.
Of course, you could always get in touch with the manufacturer to purchase replacement parts directly from them.
  • Shenzhen Xinhuahui Industrial Co., Ltd.
  • Add: Flat 12B, Block 1,Nanguo Bluilding, Hongling Road. Shenzhen, Guangdong Province,China. Zip: 518028
  • Tel: (86) 755-82450456 Fax: (86) 755-82450456
  • http://www.xinhuahui.com
  • E_mail szxhhco@163.com
Good luck and thank you for using FixYa.
Posted on Jan 25, 2009
  • 19,396 Answers
  • 10,515 Answers
What's the issue?
  • taran_2005
    taran_2005 Jan 25, 2009
    r u looking for website name ??????? parts.......................
    Guru:
  • 449 Answers
ISO cooling fan, what is wrong with it?
Posted on Jan 07, 2009
    Master:
  • 763 Answers
Sir can you pls specify the problem so that we can help you better.
thanks!
CHARCOIS
    Sergeant:
    Champion:
  • 239 Answers
Lowes.com
Have 1959 Westinghouse table fan wit Leviton switch missing power cord. Need help rewiring power cord
120v?? Neutral stays neutral, hot goes through the switch and then your ground. Three easy steps, IF you turn the power off;)
Jul 18, 2017 | Heating & Cooling
Whirlpool oven rbd275 fan
Yes, you can do this. Oven cooling fan working at 120V
Nov 06, 2017 | Ovens
Foxconn 661FXME - PC661M04-G-6L & Intel pentium 4 prescott 511 2.80 ghz
Hello you can download a manual from here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000108&Language=en-us
But BE CAREFULL when you change the cpu.
And remember to add some cooling paste.
Here is some info about the cpu:
http://ark.intel.com/products/27452/Intel-Pentium-4-Processor-511-1M-Cache-2_80-GHz-533-MHz-FSB
You will get better performance with a new mainboard/cpu
as this cpu only has one core.
Good luck
Oct 06, 2012 | Null Computers & Internet
Code P0A93 for toyota PRIUS WHAT IS THE PROBLEM ? Check Engine light and ! and VSC Warning lights I looked up code P0A93 equals StandaRD DTC'S (ISO 15031-6/SAE J2012) WHAT THIS MEAN?
P0A93 is an inverter cooling problem. The inverter is cooled by a dedicated cooling system, which consists of an electric water pump, cooling fan, and radiator. This cooling system is independent of the engine cooling system.The mechanic should check if there is sufficient amount of coolant for the inverter, check if the coolant hose is not bent or clogged, if the water pump / cooling fan motor connections are ok, and of course if both of the cooling fan motors are OK
Sep 20, 2010 | 2004 Toyota Prius
What cause error code 511 cpu fan not detected
3 wire conductor fan. The 3RD WIRE IS THE fan sensor located in the fan's electronics this is malfinctioning come in tthe construction of the fan itself.
Aug 23, 2010 | HP Compaq d530 SFF PC Desktop
Check engine light error code 480
P0480 Cooling Fan I Control Circuit Malfunction
Chrysler has issued a TSB (#18-004-07)containing the fix for an inoperative cooling fan on 2005-06 Caravans and Town & Country vans with the 3.3L or 3.8L engines. The problem usually occurs after driving in heavy snow conditions where snow and ice form at the bottom of the fan shroud and block the fan blade. This condition also sets a P0480 code in the PCM. The fix requires a PCM reflash. If you have an inoperative cooling fan or a P0480 code, check the version label attached to the PCM. If a software update has not been performed since this TSB’s issue date of January 24, 2007, you should have the update performed before you start replacing any parts.
Dec 13, 2008 | 2005 Dodge Caravan
U-Line 15WC Wine Cooler Logo
121 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Sal De
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
