Question about Franklin Freezer Chef FIM70 Commercial Ice Maker
Ice Machine FIM600 Ice is making too big
What do I need to do to get the machine to make smaller ice cubes
  • Farley Redfield
    Farley Redfield May 11, 2010
    If I knew what kind of cubes I might have some advise. Any idea of who made the machine?
Remove front cover to view control panel. there is a cube size adjustment there. use a small screwdriver and turn it counterclockwise to make the cubes smaller
Posted on Apr 06, 2009
Ice machine not making enough ice
Need some more details. Size of cubes too small? Batches of ice take too long to make? (Over 45 minutes?)
May 16, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Ice thickness control
The ice thicknes control is located on the bottom left. it has a wire going
to it and ha a black rubber bottom. depending on the position it is secured.
will determine the ice thickness. loosen the two screws and push it higher
for smaller cubes and lower for bigger. If you are having problems with it.
There is the possibility it is dirty and sticking.
Jan 14, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Very small ice cubes
how old is the machine? check the cube size control
Aug 15, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Km500mae never shuts off
this is easy to fix first you need some food grade hose next put this hose in the bottom of your ice bin then run you water through this hose to the machine fit as much hose as you can in the bin floor and start the machine at night and the other thing you may wish to do is get a remote condenser
Apr 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Jun 11, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Franklin Freezer Chef FIM70 Commercial Ice Maker Logo
266 people viewed this question
Top Franklin Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
mike cooper
Are you a Franklin Freezer Expert? Answer questions, earn points and help others
