Question about Zenith IQB50M90W 50" Rear Projection Television
Parental Control Passwords
I Bought this tv from an estate sale very cheap but nobody knew the parental control pass word and all I can watch is PG. Is there a way to change wthout knowing the old password?
  • Anonymous Mar 18, 2014
    i bought a ipod and it has parental control on it and i dont know how to get it off
According to the owner's manual, if you forget your code, just reenter ?7777? to reset to factory preset code.
Posted on Jul 11, 2007
  • Gabriel Pedroza Jul 11, 2007
    thats 7777 without the question marks. : )
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
I have a sony playstation 2 i do not know the parental password and i cannot watch movies my daughter bought becuz it will ask for parental control to be set to level 8 and u can only say yes or it will...
try passwords 1111 and 7444. these are known sony default passwords. if that doesn't help, unplug it and leave it like that for 72 hours. that should drain the charge enough so it "forgets" the password.
Jan 31, 2011 | Sony PlayStation 2 (PS2) Console
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I bought a system from a co-worker who up-graded to a PS3... he had a parental block o it for his children... I wanted to watch a DVD on it and it asked for a pass-word... I called my co-worker but he...
Here it is better give me 5 stars for this one :)
Power off your PlayStation 2, and place a DVD into the disc drive. You can reset and turn off parental controls only through the DVD menu, not within the game menu.
  • Step 2 Start the DVD, and wait for the message informing you that the movie is classified as beyond the "Parental Control Level" and asking if you still want to play the movie. Select "Yes," and click "X."
  • Step 3 Click "Select" on the screen that prompts you to input your password. The screen will change to the "Delete Password" menu.
  • Step 4 Enter 7444 as your password, and then click "X." This is the override password and will result in the deletion of any previous passwords.
  • Step 5 Press "Select" to return to the password entry menu. Choose a four-digit number to enter as your new password. If you're going to disable parental controls for good, enter 0000, as this will be the easiest to remember and enter. Repeat the entry when it asks for confirmation.
  • Step 6 Click "Select" when the move begins to play. Use the directional pad to select "Setup" from the menu that appears. Next choose "Parental Controls." Change the level to "Off," and exit the menu. Your parental controls are now turned off.
  • Dec 29, 2009 | Sony PlayStation 2 (PS2) Console
    I accidentally activated the parental controls on my samsung tv and now I can't watch any stations with a PG rating. please help!
    To change this, you need to access the Digital Menu, Setup, Parental Lock and turn the lock for PG off. Or enter the 0000 code.
    Jul 15, 2009 | Samsung HP-T4254 42 in. Plasma Television
    Trutech TV parental control
    naughty naughty, we have been caught before!
    Ask your parents to give you the password. Passwords are there to stop inquisitive kids from watching unsavoury things.
    If you are an adult then use the Payable request to prove you are of age and not a child trying to subvert Mum and Dads password.
    now go to your room and think about your punishment when your parents find out about this
    Jul 05, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
    Parental Control V chip has been activated.
    on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
    press and hold volume up and channel down simultaneously until message is cleared.
    This turns off parental control and clears the password.
    Sep 06, 2008 | Sharp 19R-M100 19" TV
    The parental control is on and cant play games. dont know passwords
    Go to Settings
    Highlight Parental Control
    When the screen pops up that says Enter Pass Code press: X, Y, Left Trigger, X
    You'll be taken to the parental controls screen where you can disable the passcode previously entered.
    don't tell your mommy on me now...lol
    Aug 14, 2008 | Microsoft Xbox Console
    Mitsubishi parental control reset for tv model vs-5061
    I can help you unlock your Mitsubishi HDTV V-Chip.
    Please follow these steps to bypass the vchip or reset the V Chip password.
    I hope that helps.
    _______________________________________________
    Reset Mitsubishi HDTV VChip Password
    Bypass Mitsubishi HDTV Front Panel Lock
    Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
    Parental cotrols
    I had the same problem and all I did was : when it asked for a parental code i put in 6688 and that fixed mine.
    May 27, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
    Zenith IQB50M90W 50" Rear Projection Television Logo
    140 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
