Question about Lucien Piccard 26024 Wrist Watch
Add links to a Lucien Piccard 26006SS
I need to add links to a Lucien Piccard 26006SS and cannot figure it hout..plese help!
  • 2,334 Answers
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
I have a lucien piccard watch, purchased probably in the 70's. Would it be water resistant?
Yes, I think that your Lucien Piccard Watch is water resistant until now as long that the gasket of the caseback is still intact. and for you to find out that the gasket of your watch is still intact then, you should bring your watch to the expert to check your watch gasket. i hope i solve your problem.
Jul 09, 2011 | Lucien Piccard Watches
How do i remove links from a ceramic lucien piccard watch?
Browse through my Tips and Tricks. There you will find how to add or remove links.
Feb 24, 2011 | Lucien Piccard 26024 Wrist Watch
Looking for a leather band for a lucien piccard
i only found some for women sorry !!! http://www.newegg.com/Product/Product.aspx?Item=9SIA01C0001NU2&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Watches-_-Lucien+Piccard-_-9SIA01C0001NU2
Nov 09, 2010 | Lucien Piccard 26024 Wrist Watch
How to size a lucien piccard mens watch bracelet - model 26932wh
mcdevito75 here, Best bet, look for a small watch repair shop in your area to help fit your watch and to save on the cost.
Jun 15, 2010 | Lucien Piccard 26024 Wrist Watch
Lucien Piccard 27094bk manual
Go to the web site "lucienpiccardusa.com/"
From the menu on the left select "customer care".
Scroll down the page until you find "instruction downloads"
Choose "three stage movement instructs"
If this is not quite what you need, you could email them.
Jan 06, 2010 | Lucien Piccard Watches
How do you get the Lucien Piccard Automatic 26570SL running?
You have to wind the watch before it will run. The watch will also need to be re-wound every 24-48 hours.
Jan 05, 2009 | Lucien Piccard 26024 Wrist Watch
Need New Watch Band
i have repaired watches like this before. I advised u to go to www.the watchery.com and www.lucienpiccardusa.com or www.ebay.com. there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
Jun 14, 2008 | Lucien Piccard Watches
Lucien Piccard 26024 Wrist Watch Logo
336 people viewed this question
Top Lucien Piccard Watches Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Lucien Piccard Watch Expert? Answer questions, earn points and help others
