Question about Canon MX300 Office All-In-One Printer
Replace ink cartridge
How do I replace ink cartarage?
Make sure you have the replacement cartridges, turn on machine, lift th e scanning unit and pull the support leg down. The cartridge holder should move over to the left side. remove empty cartridge by pushing down on the front edge and then pull it out. get the new one out DONT TOUCH ELECTRICAL CONTACTS OR PRINT HEAD NOZZLES FOUND ON THE SIDES. remove orange tape,and insert back into machine. black in "B" slot and color in the "C" slot. push up until it clicks into place.
Posted on Jan 07, 2009
My Brother 465CN recently decided that even though I have a new black ink cartridge in, that there is no cartridge.
The code is within the ink cartridge itself. If it is not a main brand cartarage, you may have th esame problem with both . I would suggest buying a main brand one .
heads can be cleaned with a tooth brush and alcohol. Dry well.
www.brother-usa.com
Jun 29, 2014 | Brother MFC-465CN InkJet Printer
Black ink cartarage keeps flashing
It flashes when the ink has run out so replace or refill the cartridge (remember to get the counter reset at the refill shop).
Jun 27, 2012 | Canon PIXMA iP4200 InkJet Photo Printer
Will not print black only.
take a STRONG, THICK sponge and cut it to the size of the hole that you put the color ink cartrege.Dampened the sponge in hot water (better yet...place into microwave oven for 1 min) Got to be dampened HOT but not drupey wet and place into hold of printer for 1 min. rub sround inside. If color comes out on sponge (that is good) you have loosened the clogged inkjet holes. Your ink still good? on the same HOT, DAMPED sponge placed the cartarage head down on the sponge and rub like you mean it. BE CAREFUL of the metal contacts & ribbons running up the front of cartarage.
Sep 01, 2011 | Brother DCP-110C All-In-One InkJet Printer
Replaced black cartarage with brand new one and it says incompatible ink cartarage
remove it and clean its contact leads and put it back firmly till a click is heard.
Jan 05, 2011 | HP C4680 All-In-One Inkjet Printer
Why the colour print is not best quality
hey you need to clean your ink cartarage by the printer properties first click on printer properties or help tab you can see there printer properties after click on print cartarege there is a option clean print cartarage .this is the simple or fast way to clean or make best quality if it works plz reply or vote i hope it will work
Oct 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
Ink problem
Sometimes it's cheeper to get a printer on sale than buying cartarages,
However remove the ink cartarages and clean the print heads off, sometimes this works.
Verify thay have ink.
and to save a little money get a referb cart off ebay I have had good luck getting cheep ink there
Apr 25, 2009 | HP DeskJet F4280 All In One Printer InkJet
Removal of cartarage of hp psc1410 all-in-one inkjet printer
Step1: Make sure the HP is on and paper is loaded in the tray.
Step2: Gently lower the print carriage access door at the front of the unit. Do not force it.
Step3: Press down on the print cartridge gently to release it. Pull it towards you and remove.
Step4: Gently clean the cartridge with a slightly moist paper towel and then pat dry
Step5: Slide the print cartridge into the empty slot, and gently push forward until it clicks into place. If it does not click, do not force it. Remove it, and try again.
Step6:
Close the print carriage access door. An alignment sheet will print to make sure everything is lining up.
Hope this helps & happy holidays!
-TJ
Dec 15, 2008 | HP PSC 1410 All-In-One InkJet Printer
MP530 will coply but won't print
sir,
Try to replace the cartidge maybe your cartidge is not fit to work properly and also the ink is not compatible with your printer
then after you replace the cartridge do the nozzle cleaning until its ok.
yours,
alecz
Apr 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MX300 Office All-In-One Printer Logo
56 people viewed this question
old marine
old marine
