Question about Maytag Neptune MAH5500B Front Load Washer
Black mold I have lived in the same house for 7 years and I am a health nut so i am very heaslthy buy in the past year I have come down with so many symtoms of black mold. I am wanting to know if I get rid of the black mold will I start to get rid of the problems ie, asthma,headaches, memory loss, depression, stiffness..
  • massage4u2hv Jan 07, 2009
    thank you for the info...
  • 126 Answers
You could try cleaning the gasket very thoroughly with bleach water especially any creases and folds. You will likely have to do this on a regular basis to keep the mold from coming back. Beyond that you could replace the gasket but there is still no guarantee the problem wont happen again with the new gasket. I hope you can at least alleviate some of your health issues. Good luck.
Posted on Jan 07, 2009
    Sergeant:
    Champion:
  • 262 Answers
YES GETTING RID IF THE MOLD WILL HELP YOUR PROBLEMS BUT YOU WILL HAVE TO GET RID OF ALL THE MOLD AND ALSO CONSULT YOUR DOCTOR FOR A CHECK UP SOME MOLD SPORES CAN CAUSE SERIOUS DAMAGE
Star Health Insurance
FIXYA has no idea check with that company
Sep 18, 2017 | Star Health & Beauty
In court can a 16 decide which parent they want to live with?
What were the terms of the divorce and custody? Call the local Family Services
Jan 04, 2017 | Municipality
We have mold along the inner rim of the rubber gasket between the opening and the door. How can we get rid of/prevent?
Robert, You can buy or make up your own mold Rid/ cleaner, which you will spray on bad areas and wipe off. Tip if possible leave washer door open so trapped moisture can air dry.
Check the attached links, for mold Rid/cleaners.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Concrobium Mold Control 946 mL The Home Depot Canada
http://blackmold.awardspace.com/kill-remove-mold.html
Amazon com CLR PB CMM 6 Mold and Mildew Stain Remover 32 oz Spray Bottle...
Mar 10, 2016 | Bosch Vision 500 Series Front-Load Washing...
Need to talk to someone
HI I AM A OLDER PARSON AND HAVE BLACK MOLD IN MY HOME I LIVE IN A MOBILE HOME AND NOW HAVE BLACK MOLD MY WIFE IS 67 YEARS OLD AND I HAVE TO FIX IT OR IT WILL KILL US NEED HELP BAD PLEASE
Sep 25, 2013 | ReverbNation Music
Black Mold on Miele Dishwasher.
Dear Sir:
You must contact to your company supplier, and explain the problem
Can be the possibility that there are some bad design materials, and get some new replacement with better design material. Is not there the first time that this thing happen.
Get the support online, right now.
God bless you
May 15, 2012 | Dishwashers
Future value
When you buy it is worth $60, 000
I will assume that at the end of a year it is the whole new value of the house that is increased by 5%.
After 1 year value=60,000*(1+0.05)^1
After 2 years value=$60,000(1+0.05)*(1+0.05)=60,000*(1.05)^2
Do you see the pattern?
After 7 years, the value of the house will be 60,000*(1.05)^7
However if the increase is not compounded
Then after 1 year value=60,000*(1+0.05)
After 2 years, value=60,000*(1+0.05+0.05)=60,000*(1+2*0.05)
After 7 years, value=60,000*(1+7*0.05)
Depending on the coumpounding or not the two values will be different
With compounding: final value=$84,426.02
Without compunding: final value is $81, 000.
I showed you the possible mathematical solutions. It is now up to you to decide which is the one that applies to your case.
Jan 28, 2012 | HP 10bII Calculator
After taking my AC out of storage for the year I just discovered Black Mold growing inside the unit . Is there a way to take off that air flow screen and get in there to clean it out? What would be a...
remove the screen to get to it but follow these precautions.
In order to get mold out of various surfaces, it is important to first obtain proper protective gear. You should check to make sure you have all the necessary protection before you start, such as goggles and a disposable outfit which you can wear during the cleaning.
The first step is to wet the moldy area with water and soap spray. This stops the mold from continuing to spread through the air, which it will do if you do not spray it first. Then, you can use a vacuum to **** away remaining mold spores from the affected area and any surfaces close by which might also be affected by mold spores.
Next, you want to be sure to rinse all areas where you have scrubbed. You can use a wet-dry vac if necessary if too much water has collected. You should then take some bleach and water and apply it to the surface where containing the black mold. Warning: do not mix bleach and ammonia! This can lead to a deadly combination of gases. Make sure you follow the instructions on your cleaning ingredients labels.
You will probably have to leave the solution on the affected area for 6-8 hours or thereabouts. It should be able to dry on its own. You can also use fans, dehumidifiers, and any other type of air circulation device to let the area dry as quickly as possible.
It is important to note, however, that it is very important to let the mold dry; otherwise, it will reproduce. Every mold spore must have a chance to be completely wiped out to prevent it from coming back at any further date. Once the entire contaminated area has been scrubbed away, it should be okay to start using the previously affected room again for any usual purposes.
Ultimately, black mold removal must be done with care and caution. You must ensure that every surface which has been affected is thoroughly cleaned. If it is not, you run the risk of mold returning which can cause serious health problems, as mold is a deadly substance and can create huge issues for any house or building which is affected by it.
Be sure to properly protect yourself when cleaning non-porous materials or any other household surfaces while you remove mold, both to prevent damage from the mold itself and from the chemicals you use to clean it away. This is very important to ensure good safety and preventative measures for mold removal and permanent care and treatment of the moldy spots.
Jun 08, 2011 | Sovereign ARP-900E Air Conditioner
Black mold in broken Dishwasher
bleach is always good i suggest you cover the dishwasher with a good plastic film after you spay it with bleach to keep the mould inside it till you can remove it
Dec 17, 2009 | Dishwashers
Moldy smell to air
I have a maytag ac unit that kept smelling moldy. We tried spraying with antifungal, only helped for a short time. I took the unit (ac unit slides out of window case) outside and carefully removed screws only to discover the fan was covered in mold!!!! Oh my what a horrible discovery! I washed the fan blades with bleach and water mix. I completely and carefully washed and wiped down the air conditioner careful around the control box. Then I let the unit sit outside in the sun untill completel dry. Good bye mold and fresh clean cool ac!! I will do this each year now that I saw that ugly mold!! That is definetly a health hazard! I would reccommend you either thouroughly clean your unit or pay someone to do it or get a new unit right away!! Don't use that moldy unit another day!! Good Luck!
Oct 03, 2006 | Mitsubishi Mr. Slim MXZ30TN Air...
Maytag Neptune MAH5500B Front Load Washer Logo
388 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
