Question about Philips MX5060D System
Sound problem my system began popping and making a loud crack in all the speakers from time to time..almost like a surge or something. the problem i now have is the audio on all source options cuts in and out. like the volume is normal, then low and so on, over and over. each time this happens, the display light dims and returns in sync with the audio problem. can you please help me???
  • 51 Answers
There is power problem in your system please check for that, because when there is a power fluctuating in a system this will occur.
Posted on Jan 09, 2009
Popping sound
Check for any external shorting of the speaker wires. Check for kinks or cuts in the cable that feeds the speakers. Also check the posts or socket at the back of the speakers for damage or wiring shorting out. Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | JVC Mx-kc38 220w Compact Component Audio...
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
TV made a loud crack or pop and the screen went black
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
Nov 10, 2009 | Audio Players & Recorders
Bizzare problem with the color
Sounds like something may be wrong with your cable line might need to have it checked.
Aug 19, 2009 | Sony KV-32FS13 TV
Hello, had error code PF on the clock display area, and oven has been making a loud "popping sound when it ignites. Havent used since that began. Thanks
Hi. The PF means power failure, A power failure wouldn't cause any problems. The ignitor does make a sparking sound. If you have a glow ignitor, it may be cracked
Apr 29, 2009 | Kitchen Ranges
Onkyo SR606 - Loud Poping
It could be a number of things,
1. an electrical short in the house. Try plugging it into another circuit with an extension cord.
2. A bad RCA cable that is input from one of your sources.
3. its probably a bad unit if you have Zone one and two playing at the same time the same source, but it only happens on zone 1.
4. a bad speaker can make a poping like sound, does it happen on all speakers? unplug all but one and one at a time try to determine if the problem sticks, if not, then one of the speakers is out of phase or blown.
5. Playing music froma computer source will sometimes make a pop if your computer is slow or bogged down with checking emails..etc. mine sometimes studders PPPPPPPrioRRRRRity CCCCCLLLLLLLLEEEEERRRRANCCCEE AAAAAAALLLLPPPPPHAAAA OOOOOOONE.
it also pops real loud when booting or shutting down.
Personal note is such a hassle for Media systems.
I hope something here helps!
Dec 31, 2008 | Onkyo TX-SR606 Receiver
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Woofer popping
Sounds like a loose connection or a blown speaker. I would try just playing around with the wires to see if you can make it pop, if so, the wire you were messing with is the most likely culprit. Also, verify the sub cone has no damage or cracks. I am betting it i a bad connection or a loose wire.
Jul 21, 2008 | Logitech Z-5500 Computer Speakers
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
Philips MX5060D System Logo
118 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
