Question about Neff W5340X0 Washer
I have a GE brand new washing machine WSSH300GWW, great front loader machine, as soon as I turned it on, I could barely hear it, loved it. But as soon as it went through its spin cycle, wow. I thought my 400k house was going to come crashing down. I thought, maybe its not level. Took a level to it, and its almost dead center. I decided to jump on top of my washer after I saw it violently moving, I could not believe that this thing would move after having a 200 lb man on top of it. WOW, what do I do?
  • 6 Answers
First thing is to make sure all of the shipping (brackets, bolts, straps, etc) have been removed.
Do FULL loads, NO partial (small) loads, these machines do NOT like small loads.
Where is the washer? Basement, first floor, second floor. Basement is the ideal place, on a concrete floor. If not, does the dryer shake when the washer does or is it just the washer? If the dryer does, the it could be the floor, not re-enforced enough. If all else fails call for service since it is NEW, but chances are the servicer will say what I just said.
Posted on Jan 07, 2009
I have a ge WSSH300GWW front load washer. All of the lights light up, blink 3 times on the panel and the machine beeps 3 times. What could be causing this problem and is it something I can fix myself?
I would check the pump is free to turn and the filter is not blocked, then check water comes in when the solenoid switches on. Is the drum free to move or has the belt broken.
Jan 20, 2017 | GE Washing Machines
Does GE have problems with washing machine model GLWN2800D2WS, Serial number HF17 1857G?
GE Washing Machines
Not cool not good reviews, your issue mentioned in several ways.
I have Samsung front loaders, love them. Direct Drive, amazing not brand new machines. I'd look at sears outlets they have tons of local stores no a days...
good luck!
Cheers
Chance
San Diego, CA
Sep 20, 2016 | General Electric Washing Machines
I TOOK THE 2 SCREWS OFF OF THE DOOR LOCK, THINKING I WAS REMOVING THE FRONT PANEL OF MY GE WSSH300GWW
First unplug the machine. If you remove the bottom panel you can reach all the way to the door lock position and should be able to reattach it easily. Why if i may ask were you trying to remove the panel?
Jan 27, 2013 | General Electric WSSH300GWW 3.5 Cu. Ft....
Washing machine won't spin the clothes it's a brand new front loader stackable unit
If you have a new machine, did you remove the shipping bolts that secure the washer tub?
Dec 31, 2010 | GE Washing Machines
Bra wire stuck inside washer between drums - WSSH300GWW
If you are unable to remove the wires from inside using needle nose pliers, then my advise is to call in a professional. Taking out the inner tub on a front load machine is involved, and you open yourself up to several potential leaks as well as bearing damage.
May 04, 2009 | Washing Machines
GE front load washer WSSH300GWW moves in spin cycle
the machine is off level. open up your installation guide, and it will provide instructions on how to properly level the machine.
if you have any questions, feel free to email me at thadoggma420@hotmail.com
Jan 22, 2009 | General Electric WSSH300G Front Load...
Ge front loader WSSH300GWW
remove the front lower kick plate (2 screws on very bottom, you may have to tip the machine back a little to get at the screws). on the rt side you will find a black accordion like rubber tube that houses a filter. remove this tube for inspection of filter. If clogged clean out filter and reinstall. Be careful to reinstall oring on largest part of tube. This fixed my no drain/no spin problem. Oh yeah.....be sure to turn off the water supply to the machine, and have some bowls ready to catch water that drains out of tube.
May 13, 2008 | Washing Machines
My Ge wssh300gww will
It is probably a clogged pump (don't look in owners manual for info - curiously it isn't in there - just says call tech - bolocks!)
Remove 2 screw on front bottom panel.
Remove cover.
Plastic boot and pump are on right had side. Clean out - and use the change to buy a drink - celebrating the fact you didn't have to spend hundreds on a tech!
Mar 07, 2008 | Washing Machines
Neff W5340X0 Washer Logo
156 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
