Question about Sony Handycam CCD-TRV68 Camcorder
CCD-TRV68-Sony HI8 HandyCam
I have this model which have almost no hour usage on it but it's about 5 years old! It will play back just fine but when you switch to the camera mode the display screen stays black just like the lens cover is on and says standby in the display? The batteries are both in good condition even after 5 years! I'm sure it's probably toast but wanted an expert opinion! Thansk,Mike Wagner
    Problem Solver:
  • 5 Answers
Hi: Try going into the menu section,check to see if camera is in the DEMO MODE. Hope this is the problem,good luck. zeffy57
Posted on May 29, 2007
Hi...I have a Sony Hi8 Handycam recorder. It's about 10 years old so it's performed well. We are having trouble with recording. It will only record correctly in outdoor bright light. When I record...
It sounds to me like the aperture is stuck. The aperture is what adjusts to let in more or less light. If it is stuck closed down, it will look fine outside but won't let in enough light inside. Sadly, there is probably nothing you can do about it. You could take it to a camera repair shop, but being 10 years old, you might opt for a new camera instead. I feel your pain!
Mar 01, 2011 | Sony Handycam CCD-TRV68 Camcorder
What do i need to purchase to connect my sony handycam cdd-trv68
You need to download your movies with a Firewire cable, you must make sure your PC or Laptop has this socket, the marking near this socket on your computer has a 3 bladed windmill picture.
Your cable will set you back about £10 at most good camera shops.
May 26, 2010 | Sony Handycam CCD-TRV68 Camcorder
Will not play on new RCA LCD TV tried different
Try hooking up your sony handycam to a different monitor or tv to make sure it is putting out a good video signal using an S-Video cable. Then once you know your cords are good and you have a good video signal, hook it back up to the RCA LCD unit. If it is still not working make sure that the RCA LCD is set to receive the Hi8 signal via the S-Video cable. There may be a switch or menu setting on your RCA LCD to accept the Hi8 signal or also refered to as S- Video.
I hoped that helped and good luck!
Nov 16, 2009 | Sony Handycam CCD-TRV68 Camcorder
Manual for camcorder/sony-HI8 camcorder-ccd-trv68eE9EVT.HTML SONY CCD-TRV68 HANDYCAM
Download the manual from:
http://www.henrys.com/manuals/sony/CCD-TRV58(En).pdf
Please rate this solution as it helps us in helping you and others like you.
Sep 08, 2009 | Sony Video Cameras
Making a CD from Sony CCDTRV68 Handycam
I'm using TRV320 camcorder with IEEE 1394 firewire cable 4pin to 6 pin. Your PC also need 1394 firewire plug which should be available in ebay. AV output is for analog signal and you need to use DV in/out plug for digital signal in your camcorder. Good luck -James
Apr 07, 2009 | Sony Handycam CCD-TRV68 Camcorder
How do I change internal clock battery in sony trv68 hi8 camcorde
There is an internal battery, but it is a built in and I don't believe it can be removed. However there are clear instructions in the manual on page 69 that detail the steps you should go thru to recharge the exhausted lithium battery for the date.
Here's a link to the manual
Dec 11, 2008 | Sony Handycam CCD-TRV68 Camcorder
I have an old Sony Hi8 Handycam model CCD-TR705E. Have not used it for about 4 years and decided to upload tapes to DVD via a DVD recorder. Worked fine for the first 5 hours of film then suddenly picture...
Try to use video head cleaning cassette one more time and check. Problem still exist then....
There is a very special cassette used to clean much dirty video heads calls Lapping Tape.
This is provided only to Sony Service Centers.
You need to contact nearest Sony Service Center.
Oct 06, 2008 | Cameras
Recorder
I also have a SONY 460x Handycam Vision CCD-TRV68 NTSC video Hi8 Steady Shot not able to record a picture but will record audio, playback is the same. Unfortunatly this occured after warranty was out. Seems like this might have been a manufactors defect.
Sep 24, 2008 | Sony 2.0MP Handycam High-Definition DVD...
Instruction manuals
click on this link to download your manual : http://www.henrys.com/manuals/ , and you can print from anywhere as long as the PCs have the program installed. hope this info its helpful
Apr 21, 2008 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam CCD-TRV68 Camcorder Logo
267 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
