Question about Philips MX5060D System
There are times when my stereo will have a loud pop or crack in all the speakers. that was happening from time to time and now, the volume cuts in and out and the display flashes along with the sounds cutting in and out. it's almost as if there's something wrong with the power supply or something?? can you please help????
    Sniper:
  • 51 Answers
Yes you are correct when there is a power problem this will happen with sound..
Posted on Jan 09, 2009
At low volume it is fine after you get to about 20 on the volume it starts to crack,pop and distort very bad what is making this happen
Your speakers may say 350 watts but that is the peak wattage at which they blow up and not a wattage they can sound distortion free at. Look for the RMS wattage which is probably around 40 watts. If you look at the specs on your receiver you will see it will put out a maximum of about 50 watts but the distortion on the receiver is above 1 percent at anything over 22 watts. That means they are going to start distorting at around half volume. The other thing you might check for is a impedance mismatch between the speakers and the receiver. Is the receiver set up for an impedence output of 8 ohms but your speakers are 4 ohms impedance.
Aug 23, 2015 | Kenwood KDC248U CD Car Stereo Receiver...
When i turn the volume up to(17-20) my sound cuts out and my speakers make a cracklin noise.i have bought new speakers and rechecked all wires.my speakers are rated at 50 watts rms and my stereo pumps out...
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Car Audio & Video
How do i get my speaker to work at high volume with out them cracking,popping destort
If you are using the factory installed speakers they aren't made for the wattage output of your receiver. Factory stereos only put out about 5 to 10 watts. If you want to play it really loud you need to replace them with speakers that have a higher wattage that what your receiver puts out, which is a maximum of 50 watts
Aug 23, 2015 | Kenwood KDC-248U In-Dash CD, MP3, WMA Car...
When the vehicle is off and stereo is off the speakers are making loud popping and banging noises all the time over the last week? when the vehicle is running and stereo on no popping noises
This can be tricky; there are several things that might cause this 'phantom' problem. You did not state if you have an alarm system. The alarm may be tied into your speakers and/or linked to the stereo itself. I would not initially suspect a ground issue since the stereo works well while powered. I would suspect a power feed issue. This can be tested by removing the fuse for the stereo and seeing if the issue continues.If the problem stops, the source may be internal to the stereo and you may need to get an aftermarket stereo - or pull the fuse every time you stop ( sucky solution, I know!) . I think this may be an issue resolved by a reputable stereo shop. Possibly a strategically placed Diode may solve the problem - a hands on diagnostic is certainly called for. You did not mention if the problem decreases or stops overnight. I would think this can cause your battery to drain over an extended period of time - and ruin the speakers too, if they're not affected already. I would try contacting the Dealer first and, as this problem has gone unresolved for so long, see if you can get them to replace the stereo or at the least pay the stereo shop to fix it.
best of luck and thanks for using Fixya!!
Feb 17, 2014 | Audio Players & Recorders
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
Speaker pop
Volume is up to high to begin with or there could be some power source close to the unit that is causing it. Turn down or turn off volume and try to do it. Thsi isn't a broken system it does happen to some units, mine included butr when I do the things I have listed it is much better. It is worse with my better sound systems.
Dec 22, 2009 | Onkyo HT-S5100 Theater System
Speakers cut out and make a loud pop noise shortly after turning on stereo. It was intermittent and if it did happen it took around at least 45 minutes to do so but now only takes a couple minutes for it...
usually a pop means the speaker is damaged in some way
first test the jaclks or plugs into the speakers
the earths
then pull boxing apart
to visually inspect the speaker membrane
Mar 01, 2017 | Audio Players & Recorders
Sound problem
There is power problem in your system please check for that, because when there is a power fluctuating in a system this will occur.
Jan 07, 2009 | Philips MX5060D System
Philips MX5060D System Logo
112 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
