Question about Frigidaire FEF351C Electric Kitchen Range
Stove top I'll have something on the stove top, on low, I turn it to simmer and the whole coil gets bright orange/red, it gets so hot that the coil pops up, and the pan sticks to the coils. Yet on the other hand, if it's on medium it may or may not get above warm. What would be the first thing I should think about changing?
    Sergeant:
  • 311 Answers
The switch regulates the output[heat ]at the element,so if you set on low and it goes to high replace you switch.hope that helps .God bless ,tom
Posted on Jan 07, 2009
    Sergeant:
    Champion:
  • 262 Answers
YOUR SWITCH IS BAD FOR THAT BURNER REPLACE THE SWITCH AND YOU WILL BE GOOD TO GO
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I opened my freezer (arctica) and heard a sizzling sound -- i could see coils behind the grates on the back wall of the freezer that were bright red (like an electric stove coil on high) -- the water was...
I hope you unplugged your unit or tripped the breaker. If they are bright red then you have an electrical short that should have tripped the breaker a long time before they turned red hot.
Jul 15, 2011 | GE Profile Arctica Stainless Steel Top...
I have a Kenmore Elite Kitchen stove top (one with the burners underneath a glass plate). Model number: 911 99004990. I believe it was purchased close to or around March of 2000. The problem I have with...
I have the same problem with ours! Our 2 small burners don't work at all and the 2 larger ones only work bright red hot. I called Sears and they said there is no recall on my particular model, but there are tons of recalls on other models. The problem is with the venting from the oven doing damage to the wiring (shorting them out maybe?). We're trying to find someone who knows anything about this and if we can get it fixed as our stove is only 3 years old.
Nov 15, 2010 | Kenmore Kitchen Ranges
My Gas stove Kenmore Model #362.75471690 The
you need new glow coil for over it may looklike its working glowing orange but it isnt getting hot enough so you neeed replace it
Feb 03, 2010 | Ovens
Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Aug 25, 2009 | Whirlpool SF367 Gas Kitchen Range
Low Flame is too high to simmer
there should be a regulator between the stove and the main gas line .unscrew lock nut turn valve clockwise to turn gas down. turn down too far , will turn gas off.
Jul 30, 2009 | Kitchen Ranges
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
Frigidaire gas range FGF337
The ignitor should be almost a white hot color very bright . If it is orange or kinda reddish, the ignitor probably isn't getting hot enough to open the saftey valve. you could check the amp draw on ignitor , but most of the time if the ignitor isn't glowing bright almost white , that is probably the problem, besides that if and only if ignitor was good then i would look at the saftey valve. My money is on the ignitor.:)
May 19, 2008 | GE JGBP28 Gas Kitchen Range
Frigidaire FEF351C Electric Kitchen Range Logo
170 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
