Question about Kenmore 22622 Top Load Washer
My 22622 Kenmore washer won't drain.. I can skip that and go to the rinse and it works.
  • 530 Answers
Sounds like you have a bad lid switch. When you open then close the lid you should hear a click. if there is no click you have a bad lid switch. on the lid itself you will see a plunger when the lid is closed it plunges the switch if there is an empty hole where the frame of the cabinet is there's your problem BINGO Lid switch
Posted on Jan 07, 2009
My washer machine does everything but dont drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 04, 2010 | Kenmore 22622 Top Load Washer
Kenmore washer won rinse waer out model 22622100 any suggestions?
See the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22622100&pathTaken=partSearch
I'm assuming that it won't drain. Will it spin????
If it will neither drain NOR spin. I'd check the Lid Switch:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
If it WILL spin but simply won't drain. I'd pull the cabinet (See above) and check the pump and hoses for any blockage.
May 07, 2010 | Kenmore 22622 Top Load Washer
My Kenmore 22622 washer won't drain. What should
That has to be a bad lid switch. Flip the controls up wards so you can unplug the lid switch from the harness and see if it has continuity. If it is bad follow the directions HERE
Feb 24, 2010 | Kenmore 22622 Top Load Washer
My Kenmore 80 series will fill, agitate, but not drain or spin... I need a new lid switch. Is there any way around it until Monday when the appliance parts store opens
Yes these some pleaces open but before you call be sure to have handy the brand n model # so they can better assist you.
(877) 477-7278 Washer and Dryer parts delivered overnight... Hope this works for U "Was this helpful?"
May 09, 2009 | Kenmore 22622 Top Load Washer
My kenmore washer will not drain ater wash cycle,but when i vaccum the water from the wash tub it will spin and drain the clothes?what do i need to check ?
the pump sounds like it blocked or the drain hose is in to tight and causing an anti-siphon
first pull the drain out and then put it back in put a little water in the washer and spin it out lift the hose in the pipe see if you see water coming out if not you have a blocked pump
Apr 17, 2009 | Kenmore 22622 Top Load Washer
Lent on clothes
Not familiar with this model but it sounds like too little water is being used (small, medium, large load) or a rinse cycle is being skipped.
With enough water and normal rinse cycles, the lint should be suspended and pumped down the drain. If this is happening with every load, then it isn't working properly.
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Won't drain, rinse, or spin
That will be a lid switch problem
Nov 01, 2008 | Kenmore 22622 Top Load Washer
Kenmore 22622 Top Load Washer Logo
59 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
