Need a bit more information, Is the security light on, have you checked for spark and fuel pressure, just in case you did and know it is the passlock system then check this out, hopefully it will ansewer your problem, please rate your mechanics help.
have a great day. Sorry the pictures won't come up, but check out the site
GM Passlock I & II InformationPlease study the following information carefully
WHEN INSTALLING REMOTE START systems on a 1996 or later GM car or truck.
Introduced in 1996, GM has changed the
VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present during the start cycle. However, in the
PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. See the
GM V.A.T.S page for more information.
To remotely start a car with this feature, you must bypass the PASSLOCK system. There are two methods of doing so.. The first, is to permanently bypass this system. This is the easiest method for accomplishing your task. The second way, is to temporarily bypass the PASSLOCK, by introducing relays into the system, which retain all of the features of the system, while allowing your remotes start module to bypass it automatically during a remote start cycle.
Vehicles effected(1996 and newer): N & J body cars, such as
Pontiac Sunfire and GrandAm Passlock-1
Chevrolet Cavalier Passlock-1
Buick Skylark Passlock-1
Oldsmobile Achieva Passlock-1
1997 or newerChevrolet Malibu Passlock-II
Oldsmobile Cutlass Passlock-II
1998 or newerAll trucks , SUVs and Vans Passlock-II
It is important to pay special attention to the fact that there are many different ways of achieving the same goal. There are actually 2 different Passlock-II systems. On the next page, there are tests to establish which type of passlock-II your car has.
Relays shown are standard automotive 5 pin spdt relays, available from IEI.
A multi meter is required to measure the resistance values. Accuracy is important within 5%.
Once the value of the resistor is measured, a resistor of the same value +/-5% must be purchased (
Radio Shack, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
Passlock-I bypass procedure....
1: Remove the top and bottom shrouds from the steering column.
2: Find the 3 wire
ribbon cable, coming from the ignition switch, containing White, Black, Yellow (Sometimes White, Black, Black). These are THIN wires.
3: Locate the Black 6 position connector on the LEFT side of the steering column, right above the ignition switch position. There is a BLACK (Thin) wire in this connector, called "Bulb Test", which shows Ground with ignition in the Off position, OPEN in the "Run" position, and GROUND in the "Crank" position.
4: Turn the ignition switch to the "Run" position. Do not crank the car.
5: Cut the Thin Yellow wire and strip both ends.
6: Without cutting the Black wire, expose some of the copper.
7: Using the ohmmeter, measure from the Yellow wire (the end coming from the ignition switch), to the exposed Black wire and record the value. Measure more than once to assure you have the right value.
8: Acquire the same size resistor and 3 relays, and perform the connections shown in the diagram below.
PASSLOCK-II bypass procedureThere are 2 types of Passlock-II systems. To determine which system you have, follow these instructions;
1: Locate two wires, which are THIN and are in the main ignition harness.. Orange/Black (or Black) and Yellow.
2: Cut the Yellow wire, and strip back some of the insulation from the Orange/Black (Or Black) wires.
3: Turn the ignition to the "Run" position ( don't crank the starter). Measure and record the value measured from the KEY SIDE of the Yellow wire, to the Black/Orange wire.
4: Turn the key to the "Crank" position and release. Now read the value again.
5: If the value changed, follow "Method#1". If the value stayed the same, follow "Method#2".
These diagrams are from our friends at ALARMTEK AUTO ALARM
Need additional assistance?
