Question about Sewing Machines
Needle not catching bobbin thread
I have been using my Janome 419 S machine fine and it's only 5 months old. I've changed the threads and bobbins many times before. Then yesterday the bobbin thread was low so I took it out of the bobbin case and topped it up with thread. Now I have put it back in - exactly as was and the needle will not pick up the thread from below. I have read other suggestions on this site. I have changed the needle, I have removed the workings around the bobbin - hook case etc to check for jammed thread and can find no reason for this. It was working perfectly before! Help a dress is waiting to be finished!!
Try taking of the pressure plate and reseating it
Posted on Jan 07, 2009
My janome magnolia was working just fine and then all of the sudden the bobbin thread keeps knotting up. i've gone over all troubleshooting, cleaned out the lint, replaced the bobbin - all to no avail......
This happened to me on several occasions and finally one service tech told me not to use the needle down auto button. Instead when threading the bobbin just move the wheel toward you slowly until the thread catches.
Jul 08, 2014 | Janome Magnolia 7330 Sewing Machine
Upper thread is not catching bobbin thread
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
Jul 24, 2013 | Sewing Machines
-what causes bird nest with the Janome Horizon 7700 sewing machine?
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 05, 2013 | Sewing Machines
Top thread is breaking on Janome 6600P
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 16, 2013 | Sewing Machines
My machine keeps clogging at the beginning of my sewing
Dec 12, 2012 | Janome Sew Precise Mechanical Sewing...
I have an 8700 juki industrial machine and as I'm sewing the thread will not catch on the bottom bobbin. I'm frustrated.. It was fine the last time I've used it.
machines do not just go out of time. Is the top threaded correctly. did u miss threading thru the take up arm or take up spring change needle too.
Nov 26, 2012 | Juki Sewing Machines
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
How to fix new home machine it model No.731016401. model 360 manufactured by Janome its not sewing cloths. The thread is placed properly but when i try sewing it starts to break the thread. it turns in...
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
also check the thread take up lever to make sure the thread has not come off of it cause that can make the machine jam up also
Sep 20, 2011 | Sewing Machines
My thread keeps breaking at the end of my sewing session. not sure why, I've been sewing blocks for a quilt and I've tried to change the thread
Upper thread breaks
Lower thread breaks
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 12, 2011 | Sewing Machines
Sewing Machines Logo
249 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
