Question about Polaroid FLM-323B Television
My Polaroid LCD TV-TDX 03211C went out while I was using it this evening & will not go back on. The outlet has power.
  • prothrock Jan 15, 2009
    We found an old fashioned TV repairman. He says it's the power supply board. We have the receipt so will try to take it back to WallyWorld. We had to return the first one after we had it 2 weeks & could only have an exact exchange for the set. Hopefully they will exchange it if my husband makes enough of a fuss & the next one will last us a few more months. The TV guy said the only sets you can find parts for anymore are Toshiba &Sony. I'll never buy a Polarois set again, or Element, it's the same thing. We left our 15 year old set back in Michigan when we moved this summer because it was so big & heavy. Sure wish we hadn't. It would still be working.
    Genius:
  • 1,199 Answers
The TVs transformer needs to be replaced! This model and brand name are known for bad transformers!
Please rate responce!
Posted on Jan 07, 2009
Polaroid hdtv tdx-03211c turns on for 10secs or so and goes blank
More than likely your t.v has bad capacitors that power up the light bulbs that light up the screen. I had the same problem with a similar Polaroid t.v. and replaced two bad capacitors and that solved the problem. Take the back off of the t.v. and look for capacitors that are bulged at the top. The capacitors have the model number on the side. I found replacement capacitors at www.digikey.com for a very low price. Here is a video that you can watch on how to replace the capacitors. https://www.youtube.com/watch?v=YCSNWi3UHf4
Jul 11, 2014 | Polaroid TDX-03211C LCD TV
Polaroid tdx 03211c no signal problem?
Check for loose contacts in power outlet, RC cable, jack and socket. Change input device to some other like a DVD player. Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
My polaroid tv model tdx-03211c turns on but no picture and led on back of tv blinks constantly
Hello Edwin Ortiz---My tv had the red blinking light on the power board and i found a tiny 3amp subminiture fuse listed as F2 on the printed board. It fooled me because it did not look like any fuse i've ever seen. Anyhow the fuse was open and the problem was the two transistor listed as Q6 and Q7 on the power board.The transistors are a brand from fairchild with a part # FQPF9N50CF . They cost $1.60 each and i got them from Mouser Electronics out of texas (www.mouser.com )
On power board check F2 minifuse and transistors Q6 and Q7---make sure that you use so heat sink compound on the new transistors or they wont last long. You can reach me at justride@yahoo.com for more detail on how to fix. good luck--jim--
Sep 28, 2011 | Polaroid TDX-03211C LCD TV
No Picture only sound polaroid tv tdx 03211c
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 25, 2009 | Polaroid TDX-03211C LCD TV
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
No power ,dead, fuse good,polaroid tdx 03211c,
Is it about 2 years old? If you checked the fuse I presume you removed the back cover. A lot of these sets have problems with filter caps on the power board---easy to tell---follow the power cord to the power supply board----you will see a number of round parts with plastic on them--most are marked on the side plus and minus--and will have markings like 470 @ 16v; a 470 mfd at 16 volts, look carefully at the silver top of all of them-----it should be perfectly flat with two or three creases in it---IF YOU FIND ONE OR SEVERAL WHERE THE TOP LOOKS BULGED UP----you found your trouble---all the damaged caps(these sets vary from having 2 or 3 to 7 or more) need to be replaced with caps of the same value but WITH A HIGHER WORKING VOLTAGE--REPLACE 16 volt cap with 25 volt cap etc. If you find this is your trouble the parts should be less then 20 dollars. The reason this happens so often is many of the companies us the least expensive caps they can get---saves them money but most of these sets I have seen with this problem fail before 3 years.
if you need help or direct advice :
etower.766@netzero.net
I do this here for free so if this has helped you at all give me a vote here.
Aug 19, 2009 | Polaroid TDX-03211C LCD TV
Can't get universal remote to work for polaroid tv/dvd combo
read here
http://www.fixya.com/support/t225581-code_polaroid_tv
May 19, 2017 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid FLM-323B Television Logo
87 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
