Question about Toshiba 32A33 32" TV
Tv wont turn on can hear clicking inside
A transistor burned up twice
  • bmikeburns Jan 07, 2009
    model is CF3564B
  • Anonymous Apr 05, 2009
    Mine just did the same thing , was it expensive to fix the transister.
    Thanks
    Scholar:
  • 52 Answers
Call for a service techniction to see what the issue is, word of personal advise, buy a new tv.
issue could be consistant, not repairable.
Let me know how it goes
Thanks
Justin.
Please Rate me
Posted on Jan 07, 2009
Output transistors burns when switch on power
What make is your unit? Did you get it fixed yet?
Sep 27, 2014 | Audio Players & Recorders
Transistors burn out on one side of driver board f-2580 at switch on of signal sansui au11000
If it keeps burning out check the wiring section of the board that is powering the transistor.
A contact or a bad diode for example can cause the transistor to blow recurrently.
Aug 31, 2008 | Sansui Audio Players & Recorders
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
I have a lcd veiwsonic VA1918WM 19" widescreen first it turn off when any thing happen black e.g game loading, dark movie etc but its button always on so i push the button twice and it disply come but...
If it is running hot in only one inverter sections (there are two inverter circuits, one for top lamps, one for bottom lamps) you have have bad capacitors in the transformer circuit, if it is running at the wrong frequency due to bad capacitor, you will have to find out. It can also be bad high voltage transformer itself. Does the P60NF06 has the same ON resistance as the original, also gate capacitance is also important.
Nov 01, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Pioneer SA 9800 Ampliffier Output transistor going off frequently
I assume these are the complimentary pair that drive the speakers. On one of the speaker. You know I think you have a short in the speaker that it drives. Speaker can fuction even if there was a problem with it. I think what happened is when the original transistors shorted out it overloaded the speaker, but not to a point where it is burnt. There is nothing that can overload a power transistor except the speakers, I design a lot of amplifiers, the base input can overload it if you put dc in there, but that would make a the sound all distorted, I assume the sound seem fine. Solution is try connecting a known good speaker and I bet it wont burn out anymore. Even if the speaker look fine don't trust it.
Jun 30, 2009 | Lasonic TRC-931 Cassette Boombox
What causes to burn out one of the ignition coil of 03 bmw 325i
replace the busted transistor in your ECU. For Bosch 30011 or 30014 you can use BU323Z transistor for replacement. it´s 100% pin-compatible and released for transistor ignition systems.
Mar 19, 2009 | 2003 BMW 325
Power transitor for 17ince dell monitor
purchase new transistor of original company duplicate transistor may heat and burn solder the capacitor of same value solder fuse and better to work on series lamp protect from burning if transistor burn again then check zener and replace if faulty
Nov 12, 2008 | Dell (TR-142M4TD) CRT Monitor
ZX-8100
I'm not familiar with that particular amp but generally, the only transistors that burn are the ones in the power supply. If the adjacent transistors had numbers like IRFZ44, IRF3205 or similar, the burned transistor is likely the same as the ones next to it.
Confirm that the center and right-most leg of the burned transistor and the transistor next to it are directly connected by large traces on the circuit board. Also confirm that the center leg goes to the large windings of the power transformer. If it passes these tests, the transistor is one of the power supply FETs. The numbers on the adjacent (parallel connected) parts will be the same as the burned one.
Jul 16, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Toshiba 32A33 32" TV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
