Question about Toshiba 57H81 57" Rear Projection Television
Picture moving from top to bottom
My 2003 Toshiba Rare Projection is having problems & need help to resolved. When I turn the TV the picture is sonw & after a few second the picture moves from top to bottom anf top of screen becomes black. Please help
  • Anonymous Mar 30, 2014
    The picture seems to go on and off very rapidly. Then a blue cast will rise up from the bottom of the screen, and the flashing continues. It is hard to watch.
    Champion:
  • 317 Answers
You have a defect in the vertical circuit. most likely the vertical chip ,caps,diode and supply voltage for the chip..john
Posted on Sep 12, 2007
Blurry Picture on Toshiba 65HX81
yes the tv has convergence problem u will need a tech to reposition it
Jul 11, 2013 | Toshiba 65HX81 65" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
When i turn on my tv it starts with a very distorted picture
got the same TV with the same exact problem....what is it??? if u crack it tell me and i'll do the same...
Oct 07, 2009 | Toshiba 50HDX82 50" Rear Projection...
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Tohsiba 61HD70 Rear Projection
Yes, its a convergence problem and you may be able to fix this yourself if you have a soldering station and a few basic tools. Its possible that all that is necessary is to re-solder the pin connections on the convergence output ICs on the underside of the cicuit board. There may also be a poor solder connection on a jumper wire connection near the ICs. Its near the plastic frame. If this does not resolve the issue, you will need to replace the ICs. Remember to unplug the TV before doing any service.
Feb 15, 2009 | Toshiba 61H70 61" Rear Projection...
Mitsubishi 50705
Good Day, tree64;
More than likely the convergence problem the TV has wont be resolved by adjustments. In your situation, moving TV, the problem most likely is poor solder connections on the convergence IC's. They are large devices attached to very large heat-sinks, and have numbers on the IC'c like STK 392-560.
If no poor connections....replce.
Good Luck, big IRISH.
Jul 04, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Picture gone.
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Mar 03, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
