Question about Kenmore 72073 Top Freezer Refrigerator
Water on btm of glass shelves and water in bottom of frig
Water has been collecting on bottom of glass shelves for several months now so much water is dripping from freezer the bottom of fhte inside of the frig is running over with water out front door onto the floor. Is this an air circulation problem? or what?
  • mccoymh Jan 08, 2009
    I emptied the freezer and removed ice buildup from the area in back of the freezer, it went thru a defrost cycle and I have water in the bottom of the frig, but no where near as much as before. Also, emptied old food out and made space for air flow recommended by the company..... Will try the hair blower trick, any other ideas out there?
Sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Posted on Jan 08, 2009
Have a Samsung RF217ACRS refrigerator that is collecting water in the left bin? I do have an ice maker.
the defrost drain is stopped up...the simplest way to start is to remove food, unplug frig and open both doors for 24 hrs. a fan blowing into ref will help this process. after 24 hrs remove the shelving so you can get to the back panel... there will be 3 screws 1 on the bottom left and 1 on the bottom right corners, the 3rd is located about 2/3 of the way up the panel in the center. this screw has a square plug covering it.. after screw removal "pop" the cover being careful of the wiring at the top, after unplugging the 2 plugs set panel to the side out of the way.... now you are looking at the evaporator, just under the evap you should see a hole, this is the defrost drain.. if there is any ice in the trough remove it, with hot water if need be. once the drain is open pour 2-3 glasses of hot water down the drain to flush out.. if water wont pour through drain, I use air pressure to clear drain, if u don't have an air tank you can use a hose that you blow through to clear drain.......I hope this helps.......Ken
Sep 15, 2014 | Samsung RF217ACRS Bottom Freezer French...
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Water collecting in veg drawer and on shelves also freezing items in frig
Check the defrost drain in the back of th freezer. It may be clogged.
Sep 18, 2009 | Whirlpool Refrigerators
Water collects in bottom of freezer, then it runs out in the floor after ice has filled the bottom of the freezer. I have a frig with water and ice in the door. The ice maker is working fine, but the water...
there is a chance that the bottle that holds your water in the fridge compartment.could be broken or a line maybe disconnected this would cause water to leak in the fridge compartment.this bottle is designed to hold the water and get it cold before dispensing to your glass
Sep 16, 2009 | Refrigerators
Water is collecting in veggie bins in
I can solve your problem for you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 11, 2009 | Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore 72073 Top Freezer Refrigerator Logo
353 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
