Question about HP Pavilion a620n (PC028A) PC Desktop
Power button it got pushed in and stuck what would i have to do to fix it
    Sergeant:
  • 290 Answers
You will probably have to remove the front panel and pop the button back out from inside. Sometimes it is caused by dirt or something sticky on someone's finger making the button stick. Try carefully cleaning around the power switch with a Q-Tip and some rubbing alcohol.
Posted on Jan 07, 2009
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
I have a Dell Demension 5100, and the power button got stuck. By stuck, I mean that the power button is pushed in, but not released. It's stuck as if you pressed the power button, but did not release...
if your PC have restart button then open your PC and check the power cable slots and change them into a reset mode removing reset cable to reset slots and attach to power slot. Then you can power your pC with reset button. If you can open front case then you can outside the button .
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Head light died while driving low or high beam does not work not power to the fuse
You have a two position switch in the starter button. Push the button halfway in and the lights go out so all the power goes to the starter and ignition system for starting. Push the button all the way in and the starter engages. I suspect the button is either broken or dirty causing the lights not to work ( it is stuck in the halfway in position ) Try cleaning ,bypassing , or replacing to see if it fixes the problem.
May 07, 2010 | 1995 Honda CBR 600 F(3)S
Sometimes when i try to turn on my compAQ PRESARIO F700 i have to hit the power button numerous times before it will power up and one it went into a reboot cycle where it would never make it past the POST....
the button that you're pushing is then pushing another button on a circuit board. Sounds like the external button that you're pushing isn't making good contact with the button on the circuit board. It may be turning back off while booting up because you've had to push the button so hard to get it to come on that it is getting stuck and holding down the circuit board button - causing it to shut off right away. I'm not guaranteeing that this is the problem, but I've seen it happen before. Some of the older Compaq's had this issue. If you have a mail-button (looks like an envelope) along the top strip by the power button, then try pushing that to turn on your laptop.
Mar 13, 2010 | Compaq Presario 700 470024-192 Notebook
Squeezebox boom stuck in demo mode
Hi !
reset it !
Unplug the power cord , push and maintain the " + " button and replug the power cord, release " + " when you see " Factory reset ", then Fixed !
Have a gret day !
J -
Apr 17, 2009 | Logitech Squeezebox Duet
The menu that controls contrast, brightness ect is stuck on the menu and when i push the number 1 button on he monitor it does nothing but lock the osd. If i hit the down button the contrast will move down...
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
Mar 15, 2009 | ViewSonic VX924 19" LCD Monitor
Power button stuck
Dear MistyMae,
Almost everything on a camera is fixable. The real question is whether it would be economical to fix. You could bring your camera to one of our bestbuy stores and they can send it out to get serviced, or most larger cities have camera repair stores in their area.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 14, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Power button
This also helped me. Thanks
Oct 26, 2007 | Whirlpool LHW0050PQ Front Load Washer
Lens Stuck and No Power
I was just playing around with the camera and I don't know if it decided to work or if I pushed the right combination of buttons, but it worked. I pushed the green playback button, red camera button, and the power button all at the same time and it worked. I have no clue why it worked, but it did. Maybe it will work for someone else!
Oct 18, 2007 | Casio Exilim EX-Z750 Digital Camera
HP Pavilion a620n (PC028A) PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
