SOURCE: maytag washer door boot
Remove 2 screws holding door hinge to cabinet and remove door. Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward. Remove panel from lower clips. At top of exposed area remove 2 5/16 screws. Remove brackets under them.
Open dispenser and remove 4 screws. Careful not to drop in dispenser. Remove dispenser frame assembly.
You can now raise top of washer to a 90 degree position.
Now back to front exposed area. Grab boot where it contacts front and peel out of groove. Also remove two screws holding light assembly and remove cover. Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel. Remove front assembly by folding up and onto top.
Now we are at the boot. Remove spring and wire assembly holding boot to drum. Make note on boot position and spring position. Remove boot. Install new boot onto drum. wrap wire around drum with ends at top. Now the fun! Hook spring to on end of wire and using vise-grips, pull to other end to hook into wire. It can be done, honest.
Now just reverse to reassemble. should be instructions with boot. Good luck!
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
SOURCE: Maytag Neptune Front Loader washing machine - door won't lock
It won't spin because the door won't lock. The door won't lock because the door lock mechanism is bad. I ran into this many times with the Neptune's when I was working for Sears. It is not a very easy fix. It is a pain to get to that door lock and replace it. You will most likely need a repair person to come out and fix it. I hope this helps you, sorry to be the bearer of bad news. I hope you have a good rest of the weekend though and let me know if you have any other questions. Good luck.
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
